R
RByers91
- Joined
- Nov 3, 2013
- Messages
- 46
Just wondering which bulb you would recommend over the other and why? Trying to replace my H11 low beams and 9005 highs. Thanks.
Where would I find these 9011 HIR bulbs? I've found some normal 9011's on amazon, but no where does it say HIR. Is there any difference between these two?
White light is white. Light described as "whiter" or "crisper" or "cheesier" are none of those things. The color temperature of the HIR1 is about 3450K, if it gets the proper voltage. Anything "whiter" than white probably has blue filtering, which removes some yellow light-- but what you might see as "whiter" is a trick of the eye.I would also like them to be whiter, will these bulbs do that for me?
I figured I'd just ask you guys this question instead of starting a new thread. My mother-in-law has an 07 camry with stock halogen projectors. Would the h9 bulb (instead of the stock h11) be safe to use in this situation?
Her headlights are absolutely horrid.
Also I've read somewhere that since my car has a bulb shield it would be fine to run h9's.
