I now have 4 Luxeon 1W Star/O leds and am putting together a front bike light which will run from a generator (variable frequency AC, approx 600mA constant rms current - rectified to DC)
I have them in 2 parallel strings, each of two LS in series.
Am I being too conservative? Could I just run the LS at 600mA as some people appear to? - cutting the number of LS to just two connected in series?
- as if this is true, I may try all four in series as the generator is capable of putting out over 12V rms at 600mA rms when speed is high enough.
Note, I seem to have two sorts of LS/O, the older type is dimmer with a lower V-drop,
AND
Can a simple lens be applied to narrow the beam of a LS/O?
+/- 5 degree would be better than the existing +/-10 degree
Thanks-in-advance for your wisdom
AND
