Re: P2D body...... 4sevens HELP ME....!!!
CeilingDweller said:
Thanks 4sevens! Would the P1 Holster be a good fit?
No, the P1 Holster is a bit short. The P2D holster is just a tad bit longer.
Sorry I don't have any yet in stock.
Dobbler said:
Are the P2D/L1D/L2D tailcaps identical?
From memory, I don't think so. The P2D and P3D's have different
tailcaps. Threads match, but the 123 lights have a slightly larger dia.
Robatman said:
4sevens,
can you confirm if this will work with the p3 head, I know the web site says
ONLY compatible with the L1D CE, L2D CE and P2D.
will there be....
- no output,
- reduced output
- flickering cos its thinks its low battery
thanks
Robert
It may work, but it's not compatible.
The L1D, L2D, P2D share the same head so they are identical exact
replacements
The P3D head was never designed for a single cell with the P2D body.
So it's up to what hobbyist to explore. No guarantees.
But from I'd experienced, they work fine together. I used AW 123's
and get a good amount of max output, when low battery indication comes
on, I just bump it down to high output and it's steady. As to when the
battery indication comes it, it's a factor of:
1) Vf of the XRE
2) The drive current (which affects the Vf)
3) Internal resistance of your li-ion cell
So ymmv, but for me it's worth it since you get all the levels with
a li-ion cell.
