Re: Dereelight, LumaPower, or Tiablo???
I'm actually not sure if the 2SD delivers more than 1A to the emitter, but Alan provided me with these figures as far as the current being drawn from the battery, with an 18650:
3.0V--->2.0A
3.6V--->1.5A
4.0V--->1.2A
As the battery's voltage drops, the circuit pulls more current so it can keep powering the Q5 with the voltage it needs to keep running at 1A, and keeping the level as constant as possible until the battery is exhausted.
Well, I'm confused now, because according to what battery each of the models can use:
Battery:
- 2SM(2-stage mutipower) module: 1x18650, 2xCR123A, 2xRCR123.
- 1S(1-Stage) module: 1x 18650.
- 2SD(2-Stage digital) module: 1x 18650.
... you would think that it would be the 2SD that would work best with 2xCR123A's because they would offer the highest voltage and runtime over the comparatively lethargic 3.7v 18650.
If the 2SD pulls higher voltage, you would think that the best batteries for it would be 2xCR123A.
In the scenario you describe above, it's the 2SD that would pull the 18650 down to an unuseable voltage level more quickly, so you would think that the very best batteries to use in the 2SD would be the 2xCR123's.
Yet, the above suggests that you can only use the 18650 in the 2SD.
I'm about to order a DBS today, and I lean toward the 2SM specifically because it has more battery options (18650 for normal use but 2XCR123's as backup for when the house goes dark for days and recharging isn't possible).
So I'd like to get a mental handle around this before I order, and based on the other specs given for the three versions of the DBS, they state that all three of them pull 1amp as their "high" level.
At the same time, I do wonder why all three of the DBS lights can't use all of the same battery options.
I guess I need to wade through the zillion post thread to find a better answer.
