big beam
Does anyone have one of these lights yet and do tell if you do.
DON
DON
I've noticed a fantastic tint on both my lights with 0100 Rebels.Just got mine! It does have the OP reflector, which I wasn't sure if it would have or not. So it has a nice beam. The tint is much nicer than the tint from my regular P3D, it's more white and warm (makes my regular P3D's beam look very purple/blueish in comparison). The lower modes look brighter. It's kinda of hard to tell a difference on Turbo, because the OP in the Rebel version spreads out the hot spot, so the hot spots look about the same intensity, but since the hot spot from the Rebel is larger it does seem to be putting out more light. I am having some issues with the UI (clicky) so I might have to try cleaning the contacts etc. Hopefully that will clear things up. Say I'm in turbo, I turn it on and it goes straight to strobe and tapping and clicking on and off won't get it out of Turbo, but twisting the clicky cap to turn it off and on cycles it to the next mode.
The beam tint and quality is a huge improvement over my regular P3D. I will play with these more tonight when it gets dark out to compare throw.
Thanks for the beamshots, dramatic difference:twothumbs.
I think the difference is most dramatic when they are both set to LOW. Is there some kind of curve wit these new LED's? Like there is a larger % increase in lumens at lower current, than at higher currents?
Have you used RCR123's yet?
