Thertel
I am search for a P60 style drop in that runs on 1 cr123a for use in a older surefire 3P, I tested the fit on a malkoff unit and it fits fine but needs a different driver. Any help would be great.
You want a LED based P60 drop in that can run on 3V? Both Nailbender and Dereelight have P60 drop-in that can run from 3V (or less).Any 3V incandescent dropin suggestion?
Well, I don't know much about incandescent P60's, but the Dereelight and Nailbender LED drop-ins are about $35-40 and use the latest Cree XP-G R5 LEDs.Either incan. or led is fine.
I am looking for cheap drop-in which can run full power with the FM 1x CR123 body.
I would expect a good P60 to pull considerably less than 2A from the battery in order to deliver 1A to the LED from 2xAA's.I use the M30 with two NiMh AA's as well, and it holds steady at 1A draw at the tailcap. I use Eneloops. I would guess that XP-G's delivering 1A to the LED would be pulling close to 3A's at the tail.
