D
**DONOTDELETE**
Guest
I tried to run a sure Fire p60 lamp assembly on AAA, AA and D-cells.
First I used 4 D-cells, but the light output was bad. When i added two more D-cells the light output is nearly the same than the p60 with two litium batteries.
Is there anybody who tried the same? Can the p60 lamp be run on this configuration savely, because 6x1,5 volts are 9volt. The same thing did not go with the P61. The light output on 6 batteries was bad. It would be interesting, to use the p60 in other lamps, because the coasts are lower.
