S
swrdply400mrelay
P60 Module
T50 flux Bin E4 4500K neutral white
2 level HI / Low
2.8 amps
Smooth reflector
CPF ID: swrdply400mrelay
hi dave i love the xm-l you send me one question is the outer spring really needed , it was a little too big in a sf c2 so i removed it .
is the function for recoil protection only or do i have to cut it and install for better operation of the light thanks
greetings alexander
i've been hanging around waiting for the answer to your question, as i have the same one.
after realizing the head would not screw down with the full spring, i tried trimming it. first clipping off a partial turn of the spring, until eventually less then half of the spring was left. the C2 bezel would still not seat. i removed the spring entirely, and with the copper tape it works. i'm not sure if it's the drive levels are flaky, my timing is off, or if i in fact should be using the spring in some way, but it's sometimes skips levels.
any xml with higher voltage- to run with 2x 18650?
Hi ,I want to order:
Cree XM-L
Smooth reflector
3 level Hi / Med / Low
2.8 amps
Thermal Potting
International shipping!
Total 50 dollar
Host is a Solarforce L2P with one protected 18650 (2900 Mah)
BTW , does the smooth reflector has a nice beam with the XM-L?
Hi Dave,
Thinking of ordering the following:
Cree XM-L
T40 flux bin 5B3 tint 4000k neutral white
3.1 amp
smooth Reflector
Potting
$45
Cree XP-G
Q2 3000K 7A3 (90 minimum CRI)
3 levels high / med/ low / 3.6-9 volts no memory / 1.5 amp
smooth Reflector
Potting
$40
Cree XP-E
NEUTRAL WHITE
3 levels high / med/ low / 3.6-8.4 volts
smooth Reflector
Potting
$35
Have I provided enough details?
Is it possible to order xm-l with higher voltage?...ie 8.4v?
simon
HI
this is another question counted a couple of answers already asked and answered in this thread, as posted on the first page 6 volts max......
Dave
Hi
Yes that is all the information I need, I am sure you know that the XPG and the XPE will have some rings and small artifacts in a smooth reflector as I have previously stated. They will have better throw.
Dave
thanks again.... do you feel any of these are obsolete relative to each other? i only need two modules... throw is my main objective
HI
These are CREE emitters, all CREE emitters will have rings when used in conjunction with a smooth reflector. This has been known since the XRE days. That said I myself do not mind a smooth reflector but if you are looking for a perfectly smooth beam then NO.
The smooth reflector will have more color tint than a blended beam in a lop reflector. The corona will be more dedicated and the hotspot more defined. As I said I don't mind at all but if you are going to wall hunt then it will not be as a lop, if using in real life situations then there is not any detrimental problems with the smooth and it will have slightly more throw.
This is for each member to decide what he wants as my views may be different than yours. I sell plenty of smooth with lop still the predominate seller.
Dave
