gcbryan
This might not exist but I thought I'd find out for sure
Ideally, I'd like a P60 sized light (such as Solarforce) with a side switch. If that doesn't exist I'd like a similar sized (single 18650) light with a side switch.
I have a drop-in that I could use if it was actually a P60 host but I'm not aware of any with a side switch so I'm just looking for something that is about that size.
I don't want any crenelation or excessive heat fins. I don't want any strobes unless they are well hidden. So basically I want a XM-L or XP-G single 18650 with smooth lines with H/M/L and a side switch.
I'd consider side buttons that ramp. I'd rather not have magnetic rings that can't actually turn the light on and off.
You would think that this would be a simple request...a plain looking 3 mode light with side switch I'd like to be able to unscrew the bezel to get behind the glass to diffuse the output.
If there are several companies offering something like this just point me in the general direction and I'll go and check them out.
Thanks. Start with the more value oriented choices (if any).
