Ya that's some bad info they are giving. I was basing my advice on their website infoJust received answer from Sportac that it's not okay to use 6V.
"Hi, the 1-2L programmable circuit is disigned for 2.7V-4.2V, please do not use 2xCR123A batteries."
At the website all modules are 2,7-6 and no options to choose, but it seems random what you get.
I don't like when they don't mark the actual module with voltage limits, very easy to forget and put in two primaries by mistake.
Just received an answer that it’s not designed for Surefire. I will measure and see if it’s possible to modify.Just received another package from China.
With the Quad you can't screw the head all the way down with a Surefire 6P and you have a huge gap. Seems like it's not compatible with Surefire? Any idea how to fix?
So, I bought some Testor's model paint. I have white and red. ONE CELL ONLY lights get marked with RED on the backside, and two cells get marked with white. For my Malkoffs, I actually use a fine brush and paint the module ID (e.g. M31L, M61NLL).Just received answer from Sportac that it's not okay to use 6V.
I find the Kaidomain ones tend to mostly only work with their mostly proprietary host. You can grab one for like $6 when you buy a drop-in, and it's a great value for $6, but it's also not a super great host. It has sharp edges and just doesn't feel good in the hand.Just received an answer that it's not designed for Surefire. I will measure and see if it's possible to modify.
Remove the spring?Just received another package from China.
You got me to buy a ZFL head to run these drop-insHi @DE73
I use 2 of the Sportac modules, one in each of my current 2 most-grabbed lights when heading out the door at night. They are essentially the same product 'model' module, and ordered as such, except with 2 different LEDs. They both have the same design features (apparently internal and external), configurable 1 or 2 output levels etc., and are otherwise ostensibly the same model product; however they DO have different specified input voltage range, as indicated on the the detailed, product-specific packaging label applied to the cannister they're shipped in. The difference is keyed to the emitter they're built / shipped with.
For this reason, I suggest that the most accurate / reliable information source for input voltage range, etc. is from the source closest to the source of the product; that being the product-specific official manufacturer product label applied to the cannister the product was originally packaged in. Any information source downstream of that is, by definition possibly less reliable / accurate.
The SST20 4000K version label specs are 780L output, input voltage range 2.7V-9V, and specified power supply options are 1x18650, or 2xCR123A.
The 519A 4500K version label specs are 814L output, input voltage range 2.7V-4.2V, and specified power supply is 1x18650. No, this one could not be used with 2xCR123A.
I'm using 1x16650 in both of those lights.
They both also have a configurable 1 or 2 output level mode, and "turbo mode" which scales up the output level(s), (if configured for that), with higher supply current requirement of course, however I've not tried that.
Mine are both installed in Elzetta Bravo bodies w/older type ZFL heads. Assembled, there is what I would call a 'small gap', between the head and body shoulder. This is a documented fact with certain applications, one specific notation being:
"Insert drop-in to your SF host, or install it with spacer when installing to a 18650 body host. It's normal to leave a small gap between the head and body as the drop-in is heatsink directly with the body."
That's a copy/paste from this page, just for reference, from a now-outdated web page/site:
Both state compatibility w/ 6P on the label.
On my lights, that 'gap' is ~0.10 in. It is a non-issue for me.
BTW, I definitely like these modules so far, and would 'buy them again tomorrow';-)
If I may ask, who are you getting your info on these from - not the individual, but at what point are they working in the Sportac manufacturer / distribution chain? Just curious, as information can be a bit 'iffy' with some products / manufacturers.
Thanks, and cheers from the desert!
I removed the springs before I tried.Remove the spring?
At a precursory glance, it looks like the "rim" or "platform" at the contact side of the drop in sits taller on the quad than with the reflector. Might have to remove some of the OD on the driver side of the drop in, but not sure if it will maintain its integrity..I removed the springs before I tried.
Thank you very much for the help. I took the easy way and upgraded my fathers clone instead of measure and machine to fit Surefire.At a precursory glance, it looks like the "rim" or "platform" at the contact side of the drop in sits taller on the quad than with the reflector. Might have to remove some of the OD on the driver side of the drop in, but not sure if it will maintain its integrity..
The other option is to bore out the body a little bit,to accomodate the extra length of the drop in OD.
A rough estimate is that the length from the OD rim to the OD bezel is ~3mm longer on the quad.
Quad:
--_---__---__
___|_______|_
_|___________|
_|___________|
_|___________|
/____________\
As opposed to
Reflector:
--_---__---__
___|_______|
___|_______|_
_|___________|
_|___________|
/____________\
Another analogy would be a standard 9mm vs a 9mm luger. The luger has that nice taper to feed better, the 9mm standard does not. Same length, same form factor, but different casing.
Glad it worked out!Thank you very much for the help. I took the easy way and upgraded my fathers clone instead of measure and machine to fit Surefire.
Chat with Eagtac AliExpress store. I guess it’s a Chinese guy close to production.If I may ask, who are you getting your info on these from - not the individual, but at what point are they working in the Sportac manufacturer / distribution chain? Just curious, as information can be a bit 'iffy' with some products / manufacturers.
Interesting how all our tastes differ. The 3000k is just too warm for me. Glad you like it thoughMy Sportac SFT-40 3000K 2-mode came in today.
2.7-4.2V, so no dual cell configurations.
That being said, the tint on this is incredible. I really like the SFT-40, as it's kind of the only real high CRI thrower. Compared to my Convoy T6 with the SFT-40 3000K, this one is a touch green (and the convoy a touch rosey), but I prefer a slight green tint, as that makes things (especially outdoors) look great.
Me too, but absolutely to each their own. To me that would be almost like striking a book of matches, all at once (don't tell me you've never done it). i don't do that warm today, but when you do, it's got a heated wire in it I bet;-)Interesting how all our tastes differ. The 3000k is just too warm for me. Glad you like it though
Al Sportac I can find online says 2.7V - 6V but they seem to deliver 2.7V - 4.2V. Little bit strange. Sad you didn’t like the tint.My Sportac SFT-40 3000K 2-mode came in today.
Hey, it's kinda warm 'n cozy like a fireplace on a stick;-) Nothing wrong with that, and I'm sure it has its place in the stable! A flashlight for all seasons / reasons / moods / uses ...My Sportac SFT-40 3000K 2-mode came in today
Indoors 3000K is perfect.Hey, it's kinda warm 'n cozy like a fireplace on a stick;-) Nothing wrong with that, and I'm sure it has its place in the stable! A flashlight for all seasons / reasons / moods / uses ...
Some of the brighter emitters in 3000K aren't as warm as you might expect. The 1800K FFL MDC AA I have is so warm, it takes a moment for my eyes to adjust before I can tell it's not amber (it's a neat experience, because with amber, the colors are always washed out, but with the 1800K, you eventually start to see them more normally).Interesting how all our tastes differ. The 3000k is just too warm for me. Glad you like it though
You've got that backwards - I LOVE the tint. It looks great. The SFT-40 in 3000K is maybe my favorite throwy emitter, because it's till high CRI. It's super interesting to use outside.Al Sportac I can find online says 2.7V - 6V but they seem to deliver 2.7V - 4.2V. Little bit strange. Sad you didn’t like the tint.
Absolutely. I do 4000-5000K in summer, then 3000-4000K in winter. Inside, I really like under 3000K at night in winter. To be fair, I did grow up with 2700K incandescent lights, and back in those days, you tended to minimize the amount of lights on in summer because incandescents are 50% space heaters, haha. So, for me, winter time is when you'd have early sunsets, and a couple of lights going in the house.Hey, it's kinda warm 'n cozy like a fireplace on a stick;-) Nothing wrong with that, and I'm sure it has its place in the stable! A flashlight for all seasons / reasons / moods / uses ...
