Jagge
- Joined
- Jun 17, 2008
- Messages
- 87
I have been doing some orienteering headlamp experiments with a DX P7 flashlight. Just out of curiosty. I post here something, maybe someone gets some ideas of it.
At first I replaced battery with a piece of wood with wires to be able to use external nimh battery pack. A lot like in this thread
And mounted it on my old orinteering headlamp band I haven't used for years and did some test runs.
Then I went on, cut flashlight in half, replaced controller with KD 2.8A board to be able to use full power, glued some additional cooling elemets, soldered new wires to LED and made a belt style 5Ah li-ion battery pack (KD 5Ah D cell) for it and put some tape here and there.
Here it is by my main headlamp lupine wilma.
One mode, on/off. It stays a bit over 1 h in regulation and after 80 minutes it starts to fade - long enough for most night orienteering races. Weight 390 g with external li-ion battery. It gives about the same amount of light as 830 lumen rated wilma (but I guess both are about 600-650 lumens). I don't have beam shots, but there is beam shots of the same flashlight in other threads. This may be a bit brighter because I use 2.8A board istead of the original board.
It's about as ugly a headlamp can be, its even more ugly in real life. But it's just an experiment and it works surprisingly well.
