cyclopsed
Hi all, newbie here.
Sitting in Luxembourg (somewhere between Germany, France & Belgium)
Just giving some info about my project.
First of all: thank you to every one having given contributions (text, images, drawings, links) connected to fitting, cooling, P7 & driver related topics, found answers to nearly every question.
Thanks again : ))
Trying to do a project for a caving headlight that shall be rather cheap, simple and based upon ready-to-use components.
Parts:
- SSC P7 DSXOI D-bin
- 8X AMC7135 DRIVER (Kaidomain SKU: S004338)
- so called Nano-Dim V2, 0-100% dimmer (found on eBay Germany), look for "nanodim"
- recycled Mag-3D head, the body isn't anymore :s
- heat sink for Mag
- P7 Al-reflector
- batteries:
- actually on the test run: 3x 1.5V alkaline on NiMH in series (4.8V downwards)
- later: 4x 1.2V Eneloop in series, they will fit into the rear battery pouch on the helmet
- maybe: designing a battery pouch for the helmet taking 8 Eneloops: twice 4x 1.2V Eneloop in //
Work so far:
Soldering, wasn't a problem.
Test run:
- it's bright, I still see stars : ))
- no heating observed in any part, weird, isn't it?
Problem encountered:
I opted for the trim pot (10K) step less dimming alternative for the NanoDim board.
Works to a certain degree: dimming from 0 to nearly 5K (50%) is OK, P7 becomes brighter, but triggers at around 50% immediately to 100% brightness. Can't dim back to 0%, have to switch off, turn the pot back to +/- 5K or less and switch on again.
I guess that something is overdriving, but what ? 8-I
ToDo's:
Fitting the assembly into the Mag head, water tightening it & fixing it onto the helmet.
Meaning:
- cutting some aluminium foil (better: copper), bending it & fix it with components within head, not that easy, there in no bottom in the head.
- finding a (good) solution to fix the head to the helmet
That's it for the moment.
Thanks again : ))
Parts:
- heat sink for Mag
- P7 Al-reflector
- batteries:
Work so far:
Test run:
ToDo's:
Meaning:
