Pair of lights, wedding gift. Not nec. identical. AA/AAA, car, camping, emergency
ksilico
I'd like to aim for $100 total for a pair of (not necessarily identical) lights for brother and fiancee. Hope to throw in charger and Eneloops too. If I can't do it all in $100, I might talk to my sister about splitting the cost of the gift package.
AA or AAA ideal. Multiple batteries OK. They'll be together on many outings, e.g. camping and hiking, so it would make sense to have the two lights be different (e.g. one may be smaller, convertible to headlamp, while other has a little more power for lighting a campsite. Diffuser or lantern style would be cool, not required though). When not camping, I imagine they'll keep one or both in a car, use one for power outages, possible around-the-house chores (again, one that is convertible to headlamp like the Zebralight styles would be handy)
That said, I'll fill out the survey below---thanks in advance for your thoughts!
==================Flashlight Recommendation Checklist================
____I would like to purchase the light in person from a brick and mortar store. I am located in ______________.
__X__This will be mail-order or Online (location doesn't matter).
2) Budget: An easy question, but you may change your mind after answering the rest! :)
____I don't know yet
____Up to $25.
____Up to $50.
__X__Up to $100. (for TWO lights, costs may be same or different but total <$100)
____Up to $200.
____Up to $300.
____Essentially unlimited.
3) Format:
____I am not sure, please help me decide.
__X__I want a flashlight (hand held/self contained).
__X__I want a self-contained headlamp.
____I want a headlamp with an external pack/power source.
____I want a mounted light (typically for a bicycle or vehicle)
__(X)__I want a lantern/area light. (would be nice as added functionality, not required).
____I want a portable spotlight (it may have an external power source).
____Other ____________________________________________
4) Size:
____MICRO - Keychain size.
__X__TINY - Every day carry (2-4 inches).
__X__SMALL - Every day carry (4-7 inches).
____MEDIUM - Holster/belt ring carry. (>7 inches)
____LARGE - Big enough to need its own travel case.
____I don't know/I don't care.
5) Emitter/Light source:
__X__LED (known for efficiency, longevity, and compactness)
____I don't know.
6) Manufacturer:
__X__I want to buy a light from a large/traditional manufacturer that is ready to go out of the box.
____I would like a light from a specialty manufacturer (Possibly limited run/Custom).
____I am interested in assembling my own components. (for example a "host" or flashlight body from one manufacturer, and a "drop-in" emitter from another source).
____I intend to use "Primary"/Disposable Alkaline batteries based on the usual AAA/AA/C/D sized cells common to most stores.
__X__I intend to use "Primary"/Disposable Lithium batteries based on the usual AAA/AA/C/D and CR123 sized cells common to most stores (often a cold weather or long storage choice).
__X__I intend to use Rechargeable cells (NiMH or NiCD) based on the usual AAA/AA/C/D sized cells common to most stores.
____I intend to use Rechargeable cells based on less common formats (18500 or 18650 Li-Ion, RCR123, et-al).
____I want a light with an integrated rechargeable battery pack.
____I don't know/I need more information on power sources.
____I want a light that plugs directly into the wall (literally with prongs built into the light)
____I want a light that has a recharging adapter (your typical "wall wart")
____I want a light that snaps into a cradle (usually mounted on a wall)
__X__I want a separate/stand-alone charger (this involves removing the batteries to charge)
____I don't care
__X__I want to navigate a dark room or read a map (1-10 lumens).
__X__I want an indoor "blackout" light (15-50 lumens)
__X__I want to confidently walk around an unlit/unpaved rural area (60-150 lumens).
__X__I want to illuminate my entire backyard or a campsite (150-300 lumens). (Just one, don't need both lights to be this bright).
____I want to illuminate an entire field, the neighbor's front yard several houses down, impress my friends and neighbors, etc. (300-700 lumens).
____I want search and rescue type illumination (800+ lumens).
____SPECIAL NOTE: Burst/Turbo mode Category - There are several lights that will run at a super bright maximum for a very limited period (usually 5-10 minutes) and then will "step-down" to a lower level for thermal control. Check here if this is acceptable.
__X__All Flood: I am doing "arms length" tasks like reading and campsite cooking.
__X__Wide Flood: I want a defined flood area for semi-close tasks like after-dark campsite tasks or working on a car.
__X__Narrow Flood: I want a sharply defined flood area that will project some distance for tasks like trail walking.
__X__Wide Throw: I want a beam with a noticeable hot-center for distance throw and a significant amount of "side-spill". Good for rough trail hiking, search and rescue, and general distance work.
____Narrow Throw: I want a beam with a very tight "hot center" and minimal "side-spill". Good for distance viewing, fog, and looking through dense undergrowth.
____Turbohead: I want a far-distance projector with a sharply focused spot of light and minimal or zero side-spill. Good for extreme distance and impressing your friends.
____Less than 1 yard/meter (reading, other close work)
_X___Less than 5 yards/meters (looking for something inside a dark shed/garage/basement)
_X___5-20 yards/meters (check out a noise in the backyard)
____150+ yards (I am searching from a helicopter)
____30-60 minutes (I have plenty of batteries just ready to be changed)
__X__90-120 minutes (Runtime is moderately important, but still not critical)
__X__3 hours + (I critically need this light to run on max for extended periods in between battery changes/charges).
____Not Important (A "night-stand" light).
__X__Very Important (Camping, Backpacking, Car Glove-box).
____Critical (Police, Fire, Search & Rescue, Caving, Survival).
____I don't know.
__X__Any size switch will do.
____I need a BIG switch (I'll be using gloves or have very large hands or coordination issues).
____I want a forward clicky (Helpful for momentary activation and signaling).
____I want a momentary switch (Predominantly for use with signaling and short bursts of momentary light only).
____I want a body mounted switch (near the head, like on a Maglite).
____I want a tail mounted switch (found on the majority of today's high end lights).
____I want a remote switch (usually found on high-end bicycle headlights)
____I don't care.
____I don't know.
__X__Other, please specify No preference, but avoid accidental power-on in purse or pocket.
____A simple on-off with only one output level is fine for me.
__X__I want multiple light levels. (Some lights have 5-16 light levels.)
__X__I want a selector ring.
____I want a strobe mode. (Oscillating pattern to confuse/blind aka "Police Mode")
____I want SOS mode. (blinks in ---...--- emergency pattern)
____I want a beacon mode. (Regular flashes at full power to show location.)
____I don't care.
____I don't know.
14)Material/Finish/Coating
__X__Anodized Aluminum – either type II or III (Hard Anodized) (Aluminum, specifically HA, is the most common material/finish for today's higher end flashlights).
____Stainless steel (durable, but much heavier than aluminum)
__X__Titanium (durable and nearly as lightweight as aluminum, but can be moderately to significantly more expensive).
____I don't care.
____I don't know.
15) Water resistance
____None needed
__X__IPX4 (Splash resistant)
__X__IPX7 (Waterproof to 1 meter/30min) Would be nice, but not necessary.
____IPX8 (Submersible to greater than 1 meter for 4 hours)
16) Storage conditions
____In house (temperature/climate controlled environment)
__x__Emergency kit (long standby periods)
__x__Automobile glove-box (wide temperature swings, long standby periods, critical reliability)
____Other_________________________________________ ____
__x__Red filter (for preserving night vision). Would be nice, but not necessary.
____"Hybrid" light (bright incandescent combined with long running LEDs)
__x__Pocket/belt clip
____Holster
__x__Wrist/Neck Lanyard
____Crenulated bezel
____Non-sparking, Intrinsically Safe (IS) for use in explosive environments​
Well, L3 Illumination L10 comes to mind. Available in a range of colours but not a titanium model. Light enough to clip on to a baseball cap for a makeshift headlamp.
My choice would be the range from Eagletac something like the D25A clicky in standard or the 2014 titanium edition.Will probably push you over the budget if you bundle in charger and fuel but what a gift to give and receive,really good quality and the best holster in the hobby section as standard.
To make it extra special get them engraved.
The above two recommendations are both excellent suggestions.
I guess you could add to them a 4sevens quark in AA.
Beyond that, perhaps a stainless key chain light. Personally an AA light is too large for me to EDC so mine is one of the smallest AAA lights I could find.
DQG AAA IV in stainless with the neutral 4A tint. 5/80 lumens
+1 on the d25a ti,will push budget over a little but special lights imo
d25a top,d25cvn bottom
his and hers..........or in my case his and his(no i dont have a boyfriend:p)
They make a lovely couple :thumbsup:
They do!! cheers;),great lights,really got into my smaller lights,KeepPower 14500 in the d25a works excellent and Efest IMR 16340 in the d25cvn.
AAA still 50/50 on,AA just for me/my use a better option and still pocketable.
I don't have any decent single AA lights. Meaning at least two modes. I do have the defiant single AA, I think 80 lumens, but only a little over an hour run-time, and it's lost right now. lol... it'll show up.
If I were to get a single AA, it'd most likely be a quark, or one like your's. However, since I found that the little Thrunite Ti is larger than I care to edc, ANY AA light will be too big. My thoughts are that if I am not going to edc a light it might as well be an 18650.
I don't put too many minutes on my light each day, so I guess I top off my little aaa every ten days or so. I have a couple of 4 packs of aaa lithium primaries in the car, and a NiMH charger there too, just in case.
I really like the t10s too for an AA,its a great light,feels quality in the hand,tad bigger than the d25a and little more weighty,but feels............well you know that solid well made feel in the hand.I have mine in trouser pocket,dont really know its there(emphasis on really) as i can tell its there(which i want so i dont loose) but not in a way to...........well be in the way of comfort..........if makes sense:thinking: :laughing:
