Sold/Expired PAR36 4.5" M*g & M6 Head
Candle Power Flashlight Forum
Help Support CPF:
Ele-4509Q ... 4s 18650IMR/softstart
Ele-4509Q ... 4s4p 18500P/softstart
FM-5x26500 ... 5s 26500IMR/regulated softstart
Ele-4509Q 4s 18650IMR/softstart
Martek 4509Q
Hi Donn_,
The second o-ring fits behind the bulb, there is still room for the notch.
Frank
my Trilliant has a real nic flood ( about a 100 yards ) the box it came in
calls it a " 63821-5 Tractor Plus " with pic of it mounted on a farm tractor.
My Q4509 (aircraft light) throws a half mile or better with real real nice spot, both on 4x25500 DL, wich fit perfect in a 4-C Mag and five mega S/S tail cap
There is a replacement "Wide Flood" lens for the Trilliant, as well.
How did you get the PAR36 head on a C-Mag?
had it done locally (very costly) , it is visable but could be made invisible but looks better visible tapering down from "D" to "C", i wish we coluld get a member to make them, its real neat deal. on the Tirilliant the wide beam lens is more for a cargo lite fixture where the tractor plus nice wide beam plus quite nice throw, i checked both out at the dealer and i felt the tractor was best for my purpose. that Q4509 is "KILLER" like you said it re-coils when you hit direct drive.........I had to turn it off, my neighbors were freeking out, they thought it was a Mars landing or a air plane........i live in a retirement community where MUST peeople are in bed by 9😛M
Don, don't forget to color code Your wires if you go with the Trillant, it is marke + / - and BTW it runs very cool as you can see the finned aluminum back
The host (old Ellie with 3x 18650s) is already set up and waiting. I'm using a modded Mag switch with a D2Flex built in, and the wires are color-coded pos/neg.
Varooj, superb craftmanship--even better than I expected! Thank you sir! This started out as quite a nice "chunk" of metal! Waiting on bulbs now.
The Trilliant arrived and I took it apart. It looks like the LED is proprietary and the box says, "Made in USA".
Tanasit,
Do you power it with 3x18650?
What is tail current draw at that voltage?
Any beam shot comparison with MN20 or ???
All I need is a 4 x 26500 Megalennium now.:devil:
Wow,
That would be 4" longer than 2x26500 Megalennium.
Is there any soft start swith to work with 100 watts?
Then beam shots !
Quote:
Wow,
I think he means 4x26500 side-by-side. A 4-chamber megalennium. 🙂
I'd like one chambered for the 26650.
Tanasit,
I did try but it only lit up 2 of the 6 leds, even with fresh set of 18650 all led would come on for 2 seconds and back to 2 leds. Now the Trilliant goes into the 4x26500 body below.
Below: 3x18650 with 50Par36/NSP-12V or GE-16540 (50watt)
