Peak Beam Systems MaxaBeam- The Torch Reviews Site
Chris M.
South Wales, UK
I know I said I may not write any more, but this one just had to be done. Despite being manufactured for over 15 years, I believe this is the first time this particular light has been reviewed, at least by a "normal" site. Hope I did justice to it.
Find it in the Others section of torchreviews.net
/ubbthreads/images/graemlins/eek.gif
O crud...you got a MaxaBeam before any of us other flashlight reviewers got one. :/
(Just kidding!!! Your evaluation is fantastic as always!!!) /ubbthreads/images/graemlins/happy14.gif
/ubbthreads/images/graemlins/happy14.gif /ubbthreads/images/graemlins/thumbsup.gif /ubbthreads/images/graemlins/buttrock.gif /ubbthreads/images/graemlins/bowdown.gif /ubbthreads/images/graemlins/grin.gif
Re: Peak Beam Systems MaxaBeam- The Torch Reviews
I just posted an update regarding a couple of minor problems with the light, actually did it yesterday evening. It`s at the bottom of the MaxaBeam page. One was a problem with the lamp that meant it wouldn`t start right away. Repairable for the time being but potentially quite concerning, given the cost of replacement lamps....
/ubbthreads/images/graemlins/ooo.gif
I would contact maxabeam
does the spot weld/wire get really hot while the light is running ?
if not maybe some sort of conductive epoxy would fix it.
If the weld spot is on the outside of the bulb glass, it gets very hot, possibly even red hot.
So conductive epoxy would probably not be the ticket here. /ubbthreads/images/graemlins/jpshakehead.gif
if it is near the base and not too close to the arc - might work
I have some conductive epoxy some where that withstands 600 degrees
The wire is/was attached to the top metal contact of the lamp on the outside. It runs down the side of the glass where it is wrapped around the outside of the bulb portion adjacent to either electrode, but it is not physically attached there in any other way. Internally, the comparitively large anode glows a satisfying hot orange colour for quite a while after switching off (especially after running in high power) and I don`t doubt the external metalwork gets mighty warm too. For now it seems secure after my careful manouvering. Beforehand it was sprung away from its weld point but I managed to introduce a little spring tension pushing it *towards* the metal instead of away. High temperature thermal epoxy might work but I would not be keen to introduce any "foreign matter" within the lamp housing for fear of outgassing or burning that could damage the reflector coating. Just opening it for cleaning without getting loads of dust in there was tricky.
Given the cost of this thing, which I could only afford thanks to a decent quarterly bonus payment at work co-inciding with PBS`s recent special offer, I`m not going to treat it roughly so hopefully it`ll remain secure for quite some time. If it wasn`t just so much *fun*, it would probably stay in its hard case most the time. As it is, it hasn`t been back in there since it arrived.
your maxa beam is pretty new
I would contact the manufacturer
they should exchange the bulb for you
even if it is a discount maxa beam
the bulb and ballast is the heart of the light.
I know I should but honestly I`m so busy right now that I don`t think I`d have the time to sort out removing, replacing and especially returning the original lamp. Maybe I`ll alert them to the presence of my review and point out the problem, but otherwise I`m alright for now unless it keels over completely in the next few weeks.
The inside of the bulb gets hot enough to heat the tungsten tips to incandescence. I am not suprised a spot weld let go. One of mine looks well secured, the other just tack welded. I noticed the lamp has the word "Arc +" engraved on it. Now I do know this light is quite a bit brighter than an Arc flashlight so I wonder what this means? I have the partial diffusion filter as well and I would not be without it. Same quality and color of a photographic strobe but it just stays on! /ubbthreads/images/graemlins/smirk.gif
