MWClint
- Mountain Series
Quick links to specific pages on Peak's website (5mm Leds) - Ocean Series
Quick links to specific pages on Peak's website(SSC P4 or Lux III Leds) - Volcano Series
Quick links to specific pages on Peak's website(Direct Drive - SSC P4 or Lux III Leds) - Accessories
links to accessories listed below
***** The Following info has been converted to web form from Peak's 2008 PDF Catalog CD. *****
Mountain Series
The MOUNTAIN SERIES of Peak LED Solutions flashlights use a special custom LED that we refer to as Snow white because of its color tint. Unlike most white 5 mm LEDs that have a very blueish color, the Snow white LED is very neutral in color tint. Power output levels average per LED are 20 Candela for standard output, 34 Candela or 5 Lumens for High Power and 40 Candela or 7 Lumens for Ultra Power times the number of LEDs per flashlight head.
MATTERHORN: The Matterhorn is a small pocket LED flashlight that uses a single AAA size battery and one or three 5 mm LEDs. It is available in black Anodized Aluminum, Brass, Stainless Steel, Gold plated brass and in limited runs of Titanium. Three different power levels, High Power single LED head, (34 candlepower) High Power three LED head, (90 candlepower) and Ultra Power three LED head (120 candlepower). Battery compartments include Key Ring, Lug, and Pocket styles in black Anodized Aluminum and Brass and Gold plated brass. Battery compartments of Key Ring and Pocket styles in Stainless Steel and limited runs of Key Ring style in Titanium are available. The pocket body with the optional cap can be used as a spare battery/storage compartment.
The Matterhorn can use Alkaline, Lithium or NiMH rechargeable batteries. Use the 3.7 volt Lithium-Ion rechargeable batteries with the high power head only. Two different sized special AAA Lithium-Ion rechargeable batteries and charger is also available with a 5/8 inch or 1 inch shorter battery compartment. The special sized AAA Lithium-Ion options, (standard output or high power only), makes the Matterhorn the first true high performance key-ring flashlight available anywhere. An optional translucent cover that slips onto the head to reduce output is useful for reading menus in dark restaurants. The optional momentary switch can be used on key-ring bodies that have the removable negative battery contact.
The Matterhorn series in Black Anodized Aluminum HAIII
Next to the quarter is a lug style 10180 Lithium-Ion battery single LED light; second is the 10280 Lithium-Ion battery version; third is a pocket 3 LED AAA battery light; then a 3 LED AAA lug; fifth is the 3 LED AAA key ring; and last is a 2 x AAA 3 LED key ring. The 2 x AAA with the optional momentary switch makes for a very useful one handed shirt pocket flashlight. All come with a stainless steel pocket clip.
The Matterhorn series in Stainless Steel
From the left is a single LED 10180 Lithium-Ion battery lug style body; next is the 10280 Lithium-Ion battery lug style body; third is a full size AAA battery smooth pocket style with a 3 LED head; number four is a lug style AAA battery 3 LED light; a single LED AAA battery with removable key ring attachment is fifth from the left; and last on the far right is a 2 AAA battery 3 LED version with the momentary tail switch. All come with a stainless steel pocket clip.
The Matterhorn series in Brass
From the left is a 10180 Lithium-Ion battery single LED lug style light; next is a 10280 Lithium-Ion battery single LED version; third is a 10280 Lithium-Ion battery 3 LED pocket; the following three are a smooth pocket 3 LED AAA battery, knurled pocket and a lug style; number seven is a 3 LED AAA battery key ring; and last is a 2 x AAA 3 LED light with an optional momentary switch. All come with pocket clips.
Optional Cases
Size comparison of the optional Matterhorn batteries and battery compartments. From the left are two of the 10180 rechargeable Lithium Ion battery cases in brass and stainless steel and the green 10180 battery. Next in the middle are two 10280 size cases in brass and stainless steel and a blue 10280 rechargeable Lithium Ion battery. The two battery cases on the right are standard size AAA battery cases in black anodized aluminum and stainless steel with a common battery between. All sizes are available in pocket, lug and key ring styles in brass, stainless steel and black anodized aluminum.
FUJIYAMA: A special battery compartment that uses two AAA batteries in black Anodized Aluminum or Stainless Steel and in limited runs of Titanium is called the Fujiyama. Two power levels are available, a High Power (40 candlepower) single LED or a High Power (110 candlepower) three LED head. There is no light output decrease over the life of the batteries. With a pocket clip and a momentary switch, the Fujiyama flashlight was designed for use by medical personnel or as a handy shirt pocket flashlight. The Fujiyama can use Alkaline, Lithium or NiMH rechargeable batteries. The Fujiyama head may also be used on the Matterhorn bodies. The optional momentary switch can be used on key-ring bodies that have the removable negative battery contact.
SHASTA: The Shasta is a small pocket LED flashlight that uses a single N size battery and one or three 5 mm LEDs. It is available in black Anodized Aluminum, Brass, and Gold plated brass. Three different power levels: High Power (34 candlepower) single LED head, High Power (90 candlepower) three LED head, and Ultra Power (120 candlepower) three LED head. Battery compartments include Key Ring and Pocket styles in black Anodized Aluminum and Brass and Gold plated brass. There are also black Anodized Aluminum or Brass bodies that use two N cells. And black Anodized Aluminum and Brass bodies that have a different independent head on each end or one end can be used as spare battery/storage compartment with an optional cap. The pocket body with the optional cap can be used as a spare battery/storage compartment. The Shasta can use Alkaline, Lithium or NiMH rechargeable batteries or 3.7 volt Lithium-Ion rechargeable batteries in single cell operation only. An optional translucent cover that slips onto the head to reduce output is useful for reading menus in dark restaurants. The Shasta head may also be used on any of the Baltic Sea bodies. The optional momentary switch can be used on key-ring bodies that have the removable negative battery contact.
KILIMANJARO: The Kilimanjaro is a small pocket LED flashlight that uses a single AA size battery and one or seven 5 mm LEDs. It is available in black Anodized Aluminum, Brass, Stainless Steel, and Gold plated brass. Three different power levels: High Power (34 candlepower) and Ultra power (40 candlepower) single LED head, and a High Power (190 candlepower) seven LED head. Battery compartments include Key Ring, and Pocket styles in black Anodized Aluminum and Brass and Gold plated brass and of Key Ring in Stainless Steel are available. The pocket body with the optional cap can be used as a spare battery/storage compartment. The Kilimanjaro can use Alkaline, Lithium or NiMH rechargeable AA batteries or 3.7 volt Lithium-Ion rechargeable batteries. An optional translucent cover that slips onto the head to reduce output is useful for reading menus in dark restaurants. The optional momentary switch can be used on key-ring bodies that have the removable negative battery contact.
McKINLEY: The McKinley is a small pocket LED flashlight that uses a single CR-123A Lithium battery and one or seven 5 mm LEDs. It is available in black Anodized Aluminum, Brass, Stainless Steel and Gold plated brass. Three different power levels: Ultra Power (40 candlepower) single LED head, a High Power (190 candlepower) seven LED head and an Ultra Power (260 candlepower) seven LED head. Battery compartments include Key Ring, and Pocket styles in black Anodized Aluminum and Brass and Gold plated brass and of Key Ring in Stainless Steel are available. A double ended battery compartment is also available that can use a different head on each end or one end can be used as a sealed spare battery/storage compartment with an optional cap. The pocket body with the optional cap can be used as a spare battery/storage compartment. The McKinley uses 3 volt Lithium or 3.7 volt Lithium-Ion rechargeable batteries. A 3 volt two AA battery compartment in black Anodized Aluminum, Brass or Stainless Steel is available with an optional click-on, click-off tail switch. An optional translucent cover that slips onto the head to reduce output is useful for reading menus in dark restaurants. The optional momentary switch can be used on key-ring bodies that have the removable negative battery contact.
