I think I may have some problems with my Peak Mckinley Series. When I turn it on, it often comes on dim, sometimes it flickers, and sometimes does not come on at all. I imagine the problem is a bad electric contact in the threads, but I am not 100% sure. The problems seem to have started when I found that the original lubricant was not quite working anymore, and the turning was getting a little rough. I put a tiny dab of Militec-1 grease on the threads, and that seemed to do the trick, except that it got a little gummy, and a little later the flickering started.
I cleaned the grease, as well as the original lubricant, off with rubbing alcohol, and tried Militec-1, as well as 3 in 1 oil, and none of them work. I have even cleaned the threads off as well as I could with the rubbing alcohol, and put it together, but the flickering still continues. If anyone has any advice as to what to do, if I can fix it myself, I would appreciate it.
