Phaserburn
This light is appealing to me. I like the toughness, brightness and internal charging li-ion power. It's the new Magcharger!
McGizmo said:As to another question of your, I believe a person could put another person in the hospital with any of these flashlights.
Art Vandelay said:Lux @ 1 meter
Pelican 7060: 10,870
Inova T4: 1,665
Lumens
Pelican 7060: 174
Inova T4: 38
Price
Pelican 7060: $199.95
Inova T4 with charger: $129.00 at BrightGuy.com
Inova T4 numbers from flashlightreviews.com
I do think that driving the LED does have a downside -- that's shortened battery life. They probably had to cut the battery life in half just to gain the last ~25-30% of the lumen output.Although this light was categorized as obsolete and other things in the other thread, it would be dificult to compare it with a group of its peers at present because there aren't any that I am aware of. The XR-E die is a 2 amp part. I believe the 7060 is driving the LED past 1 amp but I am not concerned in principal about the health of the LED; especially in a flashlight where a few thousand hours is a long time! Assuming a reasonable thermal path from LED to heat sink, the light is not getting hot to any extent worthy of concern, IMHO.
The fact that the light has this relatively short runtime is probably the biggest downside. Another alternative would have been to use something larger than an 18650 (that's likely what's inside their proprietary battery, based on the 3.7V 2200mAh spec) -- in a light this big IMHO they could have done so, especially if they were planning to drive it so hard.I think based on what the light does, for 98% of a officer's nightly use, the 1.5 hours should be more than enough. The beam looks way to bright to be used for general report writing that could use up its battery before the light was needed for more of a tactical application.
I highly doubt they powered the LED higher than one amp -- doing so is above the maximum spec from Cree, which I wouldn't expect a major company that expects to warantee these lights indefinitely to do under any circumstances. It is very possible that they are higher-binned Crees, though.Nitroz said:Don,
Great review!
I would say with output like this it is possible that Pelican could of received some of the Q2, or even some of the Q3 XR-E LEDs. This would certainly take some of heat issues out of the equation if only powered at 1 amp.
Were you able to measure the width and depth of the 7060 reflector?
Phaserburn said:This light is appealing to me. I like the toughness, brightness and internal charging li-ion power. It's the new Magcharger!
depusm12 said:Well I just got off the phone with Pelican Customer Service and was told the light won't be available for general public until about June. Thought everybody might want to know.
