Pentagonlight MOLLE Light Impressions
PJD
NW FL
I don't own a digicam, so I can't post pics...but you can see a lot of pics by linking to CountyComm through this thread:
http://www.candlepowerforums.com/vb/showthread.php?t=156489
I'll start by saying that for what it is/was intended to be, this is a very nice little light for the price. The output won't fry your retinas; but then again, it's a "utility light" that's not really supposed to be a retina-scorcher!
The emitter appears to be a Nichia Rigel (the same type of LED used in the Fenix E1). However, I've had three Fenix E1's, and the emitter in the MOLLE Light is FAR whiter than any of the E1's I've had; there's a LOT less blue in the beam of the MOLLE Light. Also, the MOLLE Light has an LOP reflector, which does a FANTASTIC job of getting rid of the artifacts normally associated with the Nichia Rigel.
The switch is a "true" clicky: slight press for momentary on, full click for constant on. This was a pleasant suprise to me...I personally am not too fond of reverse clicky switches. The body of the light is made of aluminum and plastic: the body tube is aluminum, and the head and tail assembly are plastic. The up-side to the top and bottom being plastic is that it appears to be a very durable polycarbonate-resin type of plastic that seems to be extremely robust. I have no worries that it will be extremely durable. There were some concerns expressed in another thread that the plastic threads of the tail cap coupling with the aluminum threads of the body could lead to cross-threading. Under normal use I don't see this as being a problem. The threads on the tail cap are not "fine" threads; they're actually sort of wide for the size of the tail cap, and as long as "normal" care is taken when putting the tail cap on, the threads should not cross or "wear out". The rotating pocket clip seems to be very sturdy, and should have NO problem keeping the light securely fastened to whatever you attach it to.
As far as the output is concerned, it's not too shabby! I don't own a lux-meter, but I'd hafta say that it's NOT putting out the 30 lumens that's stated on the accompanying pamphlet. Then again, I've NEVER heard of a Nichia Rigel being able to pump out 30 lumens (...unless it's badly over-driven). The closest light I have to compare it's output to is my AmiLite T5 on the low setting (I have the T5 with the 15 lumen low setting). The hotspot of the MOLLE Light is just a HAIR dimmer than the T5 on low; however, the T5 has a considerably larger reflector, so it's going to put more light in the hotspot. On the other hand, the spill light of the MOLLE Light is NOTICEABLY brighter than the spill light of the T5 on low. Using that as a "measuring stick", I'd hafta guess that the MOLLE Light is probably putting out about 20 lumens, if the 15 lumen spec of my T5 on low is accurate. IMHO, I think the spill light of the MOLLE Light is it's strong point! The hotspot is VERY nice for a Rigel, but the spill light is very white, wide, and EXTREMELY useable!
IMHO, the MOLLE Light is exactly what it was touted to be: a very tough, durable, small utility light that's easily bright enough for most tasks that you'd need a utility light for. The output is smooth AND very nicely tinted, and all-in-all, I think Pentagonlight did a FINE job on this one.
Aside from my above comments I'd just like to add that I think the MOLLE Light is just plain COOL! It's (...to my knowledge) the first single AA size light to use the military "crook neck" body, which I think is long overdue. Pentagonlight could have chosen to put a Cree or SSC or some other "brighter" emitter in the MOLLE Light, but IMHO, I think this would have defeated the intended purpose. It's a utility/task light, and if you keep that in mind when you get one, you WON'T be disappointed! YMMV...
PJD
Incidentally, for the modders, the head of the MOLLE Light does NOT appear to be removeable. An emitter swap could prove to be quite a task, but we'll see...I'm sure!
I've had mine for a week now and I agree with you. It's a neat little light with a very bright, useful side spill. I like the clip. It's kind of unconventional looking but it holds very securely. It snugs into PALS webbing with no worries about losing it.
I spent some time this evening with my dremel and a small burring bit to put in a tritium marker. There is a raised ridge of plastic in a pentagon shape around the switch. On the flat towards the front of the light I carefully burred out a channel just large enough to drop in the trit and make it flush to the top. A bit of UV curing optical adhesive and its finished. It's bright enough to see from the other side of the room (in the dark, of course). Just one of those little touches that make something yours.
PJD,
Thanks for the review. I'm still waiting to receive the ones I ordered. The Rigel only outputs around 20 lumens and can not reach 30 lumens unless you really over drive the emitter. Pentagon lights claims it outputs 40 lumens on their website.
Since they are claiming 40 lumens I have a feeling they are in the process of modifying the Molle light to use the new 52 lumen Rigel emitter or possibly retrofitting the new Lumileds Rebel.
It is indeed a nice product, smaller than what you think it is, more solid than what you think it is an quite cute.
I liked the compass at the tail and the red filter that just unscrews from the tail and screws to the bezel. Very simple to use.
Luigi
Thanks for an excellent review PJD!
After reading it, I'm totally convinced that I need a few MOLLE Lights.
I think that 20 lumens is close to ideal for a small utility light. 20 lumens is enough for most any close to medium range task, and is bright enough to walk a rugged trail or even to bushwack if necessary. Any brighter than 20 lumens and the light becomes problematic for close up tasks.
I have a Streamlight TaskLight 2AA that uses the Nichia Rigel LED to output a very nice white beam. The SL TL 2AA Rigel LED must output about 25 lumens on high, because it squirts 20 lumens out the front end (as measured by Flashlight Reviews.) The Rigel LED is more efficient than a Luxeon, resulting in better runtimes.
The one big improvement I could see for the MOLLE Light would be to add a low level of about 4 lumens for close up use and extended runtime. I really appreciate the low level on my SL TL 2AA for close up tasks and for the 50+ hour runtime. But, as it is, the MOLLE Light looks to be about the most useful 1AA light available.
Anybody know of another source for these besides CountyComm? I'd just as soon get the black version without the tailcap compass and pouch.
ringzero...I don't know if they're on Pentagonlight's web-site yet, but if not, I'm sure they will be soon. I've dealt with Pentagonlight directly on a couple occassions, and their customer service and delivery time is top-notch!
www.pentagonlight.com
I just checked, and it is in fact on their site now! Hope that helped...
PJD
PJD said:
I've dealt with Pentagonlight directly on a couple occassions, and their customer service and delivery time is top-notch!...I just checked, and it is in fact on their site now! Hope that helped...
Hey PJD, thanks a lot! Wasn't aware that Pentagonlight sold direct to the public.
I like the idea of those things, when I have the cash maybe :)
Clipped onto a belt it'd be a great walking light
I was a little hesitant to buy one of these. I thought they were just gimmicky. But, thanks to all the reviews, I will be ordering one or two. Looks like the perfect little light for walking to dogs at night.
Hey ring, if you can't find a better price and you order from CountyComm, send me the pouch. I'll send you a blue tritium vial (.84mm X 3.80mm I think) in exchange for it. I'm wanting another pouch. Open to anybody I guess. See my above post.
tried to open the damn light up, but i dont think its ever going to budge, the electronics inside seem very easily serviceable, so if someone figures out how to pop it open, please do make a post.
By the way, one thing I've not seen mentioned about the MOLLE light (which I do mostly like very much - I'm a sucker for the angle-head design) is that the compass is essentially useless for most practical purpses because of the way its permanently mounted in the tailcap. First (and maybe least importantly), you can't shine the light on it. (So if you get lost in the dark and that's your only light, forget about using it).
But more importantly, the tailcap is too close to the battery. Almost all AA cells I tested (Alkaline and Li) have enough of a magnetic field to screw with the compass. It's fine if you unscrew the tailcap, but then you've got the main body of the light, the tailcap, and the battery all separated.
So I'd much prefer a version of the light that's either cheaper and without a compass, or with a removable compass that works reliably.
H. Caul
The compass actually points at the pocket clip. The only way it can be used is to remove the tailcap.
As mentioned, you now have three pieces with possible dirt or water contamination or dropping parts in a very inconvenient situation.
Mark
Just point the pocket clip to the North, very simple!
Mark
Yes, the clip is another potential source of trouble. Actually, of the three MOLLEs I have, only one of the pocket clips is sufficiently magentized to cause interference, but ALL of the AA cells in my stash (or at least all the few dozen I tested) act as fairly strong magents and reliably screw with the compass.
Oh well, nice idea, poor execution.
Flash_Gordon said:
The compass actually points at the pocket clip. The only way it can be used is to remove the tailcap...As mentioned, you now have three pieces with possible dirt or water contamination or dropping parts in a very inconvenient situation...Mark
+1
1. Useless, unless the light is taken completely apart.
2. Gimmicky - mars the elegant simplicity of a serious little utility light. Reminds me of a prize that might be found in the bottom of a box of breakfast cereal.
