Performance Review: Emisar D4 – Quad Nichia 219C LED Light
subwoofer
Hove, UK
The Emisar D4, made by Hank Wang of Intl-Outdoor, is one of those lights that has created such a stir with its stunning output levels, that if you haven't come across it yet, you will do. Hank has created a light by which others will be judged and at an amazingly low price. Coming in several flavours of LED, with varying maximum output levels, the light on test here is the Neutral White 90CRI Nichia 219CT LED version. Also included with this review sample is the 18350 tube allowing it to be used with 18350 and 16340 cells.
Taking a more detailed look:
New Review Format 2018!
Tactical Reviews is known for very detailed reviews using many high quality images. This has meant quite a lot of scrolling to read most reviews. In the new format, the review contains 'responsive image galleries' to better display these images as a slide show with captions.
NOTE: Unfortunately these galleries cannot be pasted into forum threads.
(Wherever you see the 'Read MORE' marker, it indicates that the Extended Version of the review has additional content at that point. Viewing the extended version helps support further reviews, but please ensure you return to this Forum for comments and discussion.)
(Moderators, there is a reciprocal link at the end of every review on Tactical Reviews.)
The beam
Modes and User Interface:
From OFF:
1 Click - Turn ON to memorised level.
Press and Hold - Turn ON to minimum and Ramp up.
2 Clicks - Turn ON to Max output.
3 Clicks - Enter Voltage Battery Check (longer flash indicates a 1, short flash indicates a 0. Whole Volts first, then tenths).
From Voltage Battery Check 2 Clicks to enter Temperature Check (longer flash indicates a 1, short flash indicates a 0. Tens of Degrees C first, then Ones)
4 Clicks - Set to use Tactical (Max output) Momentary mode. 4 Clicks to cancel this mode.
6 Clicks - Lockout. 6 Clicks to cancel.
8 Clicks - Beacon Mode
10+ Clicks and hold - Thermal configuration. Hold the button until the D4 is as hot as you want it to get.
When ON press and hold to ramp up or down in output.
Batteries and output:
The Emisar D4 runs on several cell types depending on the battery tube you buy. In this case there is the 18650 tube and the 18350 which also allows a 16340 to be used. Only IMR cells should be used in this high performance light and a 20A output should be considered a minimum.
NOTE: the table is not parsing properly in BBcode, so is difficult to read here.
Emisar D4 | I.S. measured | PWM frequency or
using specified cell | ANSI output Lumens | Strobe frequency (Hz)
_______________________________|____________________|______________________
18650 Max @ switch on NOT ANSI | 3082 | 16100
18650 IMR Max | 1918 | 16100
18350 Max @ switch on NOT ANSI | 2259 | 16100
18350 IMR Max | 1700 | 16100
16340 Max @ switch on NOT ANSI | 2029 | 16100
16340 IMR Max | 1714 | 16100
Moonlight | <0.1 |
There is parasitic drain. When using 18650, the drain was 22.6uA (15.65 years to drain the cells). On Lockout, the drain was 25uA (14.15 years to drain the cells).
Below is the combined runtime graph for all the types of test carried out. It includes the D4 being run in its factory thermal configuration (45°C), and then the thermal configuration taken to the max. To set the thermal configuration as high as possible, it was set while wearing kelvar gloves (the bezel reached 80°C when setting this). Tests were carried out with fan cooling.
This gallery contains the other versions of the runtime graphs.
Review Summary
_______________________________________________
Things I like
3000lm+ Max Output.
Flexible UI.
Excellent Thermal regulation.
What doesn't work so well for me
Gets hot very fast due to lightweight construction.
Maximum output drops very quickly.
