icantsee
I just got my first Phillips 5761 light put together today. It uses a 3C Mag host with a KIU switch mod and all switch contacts Pro-Golded. (Is Pro-Golded a word?) I'm using 2 E-Moli 26700 batteries. The voltage reads 3.85 on each cell. They are new cells with the factory charge. I'm using a MOP camless reflector and borofloat lens. It worked fine. I only tested in the house during daylight , but it seems whiter than my ROP high. I don't think it is enough different to notice if the lights weren't side by side. The ROP is in a 5C mag with a home modded tail cap to accept 6 subCs and the tailspring is resistance fixed. (Same reflector and lens in both lights.) I decided to further improve the 5761 by doing the tailspring resistance fix. Put it back together and the bulb flashed in about a second. I put in a new bulb and regular Mag tailcap and spring and we're back in business. I don't know how much the resistance changes with the tailspring mod or how to do the math to determine the voltage drop if I did know the value of the change. Does anyone know of a soft start circuit that would be a diy project, or is available as a package? Thanks.
John
John
