Help Support Candle Power Flashlight Forum
I wish I could play with just a couple.yeah,playing with a couple thousand of em. 😛
4sevens said:I've been playing with several thousand TOP bin SST-90's 😛
Anyone try an aspherical lens with SST-90 in a M*g?
I was thinking that this should make quite of a thrower... no need to buy a HID?
really really nice ....but...what 23mm lens? maybe this?: http://www.dealextreme.com/details.dx/sku.13702
I have this dx 23 mm lens and are really bad lens the 21mm lens of x2000 are much better
YES .. it's working perfect ...
http://forum.fotonmag.cz/index.php?s=&showtopic=804&view=findpost&p=14506
here is XR-E with small aspherical (23mm)
and here is SST-90 with KD 52mm aspherical for M*g
First of all, SUBSCRIBED!
Second of all, let's hear more about that "10A current with LDO10C driver" that you built.
I assume that's what's being discussed here ?
Yes, I use this driver LDO10C which was discussed here a time ago ... but I use it with this thermistor placed close to PCB LED ...
I've seen that thread, but the circuit design part is over my head. Are you using the LDO10C as a voltage regulator or have you managed to configure it as a current regulator? Could you share your design? I have searched CPF for a driver solution for Phatlight SST-90, but have not found an elegant, cost effective solution. (I don't consider three shark-bucks in a shark cage to be either.) Thanks.
