Photon 3 ? for someone with brain
Badbeams3
I noticed that when the batts are removed from the light it looses it`s memory and all ways starts out on high. Does this mean it`s sucking a millamp or two even when not in use to retain it`s memory? If so can you tell how much...Craig?
Will this light kill the batts in 6/12 months even if you don`t use it?
<BLOCKQUOTE><font size="1" face="Verdana, Arial">quote:</font><HR>Originally posted by KenB:
<HR></BLOCKQUOTE>
Well, let's see... it might be hard to get a measurement because of the way the battery tray is configured, but here goes.
1: The first step of course, is to FIND it.... (imitates sound of ticking clock) :0
2: Disembowel light.
3: Micro clips would be nice right about now, but they were destroyed last winter. Improvise with wire LED leads...
4: That didn't work... improvise some more...
5: Standby current is 2 microamps, or 0.000012 watts. Even for smaller batteries, this is neglegible and should not even be considered. The battery's self-discharge rate is probably far higher.
Thanks for checking that Craig, I would have hated the idea of the light draining the batt just resting
