Photon II vs. Photon III vs Arclight
geepondy
Massachusetts
I have been comparing them for brightness side by side for three hours plus now and I think I have enough information to draw a conclusion.
First of all, I really like the Photon III concept. Easy push forward for momentary light, easy push backwards for steady light. I have always preferred a simple push switch vs. the screwing of the head method, particularly for a pocket light. I will probably only ever use the high mode but it's nice to know the medium and dim settings are there should the need arise. I would consider using the auto shutoff mode but the five second blinking every time the light is turned on does it in for me. Very easy to change the batteries which is a welcome relief compared to the II.
Many tests have been done by various flashaholics in determining the run characteristics of the Photon II. I extremely so, prefer the regulated output of the Arc light as opposed to the unregulated dimming characteristics of the Photon II. I decided to do an informal burn test comparing the Photon II, III and Arclight, hoping against hope, that the Photon III with it's IC would regulate the output similar to that of an Arclight. I loaded them all up with fresh batteries and as mentioned have been comparing the output for the past three hours plus. The photon III was set in it's high mode. Initially all three lights were fairly similar in light output. The Photons II and III were very similar to each other. Both had perhaps a slightly brighter center then the arclight but the arclight had a wider beam.
Alas, I can safely say the Photon III exactly mimics the drain characteristics of the Photon II. That is, dimming considerably over the first half hour or so and then dimming more slowly but dimming nonetheless, over the remaining period of time. This is an informal test and I haven't taken any pictures or done exact time light measurements but probably after an hour to an hour and a half the Photons were down to the light level of my pocketbright and now after three hours, it's less then my infinity. But again, the two photons are exhibiting similar characteristics compared to each other. The arclight however, continuous at near constant brightness levels. I think it may be a tad dimmer then when first starting the test but not by much.
So in conclusion, the Photon III hasn't become my ultimate pocket light I hoped it would be. In terms of size and operating characteristics, it's very close but the arclight blows it away in light quality. This is a "first generation" arclight. I was very disappointed in the rubber grommet which has now broken off completely and how easily the head became unscrewed even when the rubber grommet was still present. At this point the light is useful to me only as a test light. I have on the way another arclight (thought I'd try turquoise) that I assume will be a gen II light and hopefully is improved. Anybody who has owned both generations of arclights, care comment on this? I love the workmanship of the infinity so I hope it is similar to that.
Unfortunately, still searching for the perfect pocketlight.......
Geopondy
I received a GEN II replacement from Peter today, and can assure you that it feels as smooth as an Infinity, but smaller and brighter. In other words, I think you will be very happy with the modifications.
Thanks Geepondy for sacraficing the batteries for the betterment of our community.
I too have a Photon II and Arc-aaa but was considering buying a Photon 3 just to compare. You've just saved me some money! To me the most important feature of the Arc is the constant light output for most of the battery life. (before going into moon mode) Too often I had put new batteries into my Photon II and was able to 'wow' friends and coworkers by it's brightness for it's size, but it quickly dimmed and lost it's 'wow' factor. (and we all know this is why we buy these things in the first place - right!) And you are right, the Arc has done this while still in it's first generation. I can't wait to see it's further improvements.
I think you can still save that Gen I Arc-AAA, but go right ahead and get the Gen II.
To save the Gen I, you will need something to replace the rubber grommet. I used a product from Selleys called "Leak Repair". It is from the "QuickSmart No tools solution" range. It is a self-vulcanising rubber tape. Just a length of about 10cm and half the supplied width would be enough. Just stretch it over the place where the grommet used to be and wrap it around several turns. Then insert it back in to the body of the flashlight. The rubber will self-vulcanise in to one solid piece and conform to the shape imposed by the body, so it will provide a tight seal. This is the easiest and least messy of all the solutions I tried.
Another solution I tried was to use a silicone sealant. Very messy and I finally cleaned it off and went back to the Leak repair stuff.
This should be available at practically any hardware store or the hardware section of any major departmental store like Walmart or KMart. If you can't find it and want to try it, let me know. I can send you some.
BTW, ever since I got the Arc-AAA, I have never gone back to my Photon II. I prefer the twist on action, but used the Photon because my dress pants would not carry my Infinity properly.
