Photon Microlight II
  • Thread starter Thread starter **DONOTDELETE**
  • Start date Start date
D
**DONOTDELETE**
Guest
What a discovering!!! It´s simply fantastic,...
Yes, pretty cool.
Although it is best used as backup light or casual keychain light. Use the ARC AAA on your keychain if you are going to use it a lot.
If you run it continuously like a flashlight you use a lot, the brightness will drop off quickly whereas the ARC AAA will put out pretty much even brightness for the whole time the battery lasts (5 hrs+) and then switch into "moon" mode.
