I bought a Photon Rex about a month ago. I found that it would usually not charge at all on a 1.5V battery. It DID charge on a DC power supply at 1.5 volts, at the rate of 400ma. It sometimes charged on two D's (i.e. 3 volts) and sometimes not. It was NOT an issue with the contacts; the light was defective.
I sent the light back to Photon and they replied in a form letter that you folks might like to read. I consider their response good customer service.
"...we have found a charging issue with the code in the circuit board of your Rex light. The issue only affects the light in deep discharge. If your light is drained all the way it will only start a charge with a 3 volt battery (CR123). It may take a few minutes for the LEDs to start blinking and indicate the charging process has begun. If you do not let your Rex drain all the way you can use 1.5 volts (AA, C, D cell)."
"When we receive our new shipment of Rex we will send you a replacement at no cost. Enclosed is a gift for your inconvenience and thank you for your patience in this matter."
They sent me ***a working*** light with a full charge... along with a new "X-Light-Micro" as compensation. I'm expecting a NEW 100% working Rex soon. Sure, I'd rather the first Rex was 100%. But the Photon guys DID take responsibility and they're doing right by me.
I figured I'd let you guys know about this should you be experiencing the same problem.
W.
W.
