Pics of your largest and smallest flashlights
Guitar Guy
West Virginia
This could get interesting if everyone participates.
2 categories: Physical size, and Lumen spread.
Please include make, model, and measurements / rated lumens accordingly. I used the coins for size reference. Here are mine.
JT
Physical size difference:
Maglite 6D @ 19 ½ inches, Fenix EO5 @ 2 5/8 inches = 16 7/8 inch difference
[/IMG]
Lumen ratings:
Fenix TK47UE @ 3200 Lumens on turbo, Malkoff MDC AA @ 3 Lumens on low = 31997 Lumen spread
[/IMG]
bykfixer
My own little Idaho
I'll play:
L to R then Top to Bottom:
- 1x123 SureFire Executive (crossfire logo) with Lumens Factory 45 lumen bulb- about 2.75" x0.80"
- 1950's 1xAA Fulton Tom Thumb with (2 cell) #224 bulb for about 1 lumen- about 2.75" x0.50"
- 2016 1xAAA PKDL PL2 LED for 110/12 output- about 3" x0.50"
- 1990's Maglite Solitaire with stock kryton bulb for about 6-10 lumens- about 3" x0.50"
- 2016 PKDL PR-1 LED with an RCR 123 puts out about 490/200/20 lumens- about 2.75" x0.80"
- 1980's 1xAAA Streamlite Pocket Mate with stock bulb puts out about 10 lumens- about 3" x0.50"
- early 2000's 1x123 Vital Gear with an E2D head and a 350mA Tana singLED puts out about 110 lumens on high-about 3.5" x0.80 to 1.10"
-1930's Bright Star 6D with Bright Star 4D extension puts out about 150 lumens using an Eiko KPR120 bulb- about 22" plus head
- 1950's 6+1D Dog House Supply S&R light using a 7D Maglite PR xenon puts out about 200 lumens.- about 20" plus head
- 1970's LA Screw 3+2 Monadnok edition Code 4 that puts out about 150 lumens through a 44 mm ultraclear glass using a 5 cell Maglite PR xenon bulb- about 20" total
- 1980's California made Streamlight 5D (3rd gen Kel-Lite) with 52mm ultraclear lens and a 5 cell Maglite krypton puts out about 75-100 lumens- about 18" total
That was fun.
LiftdT4R
NJ / PA
7D and Marquis! Bonus points if they rhyme? The 7D is 22" and the Marquis 3", so a difference of 19". The 7D puts out around 150 lumens and the Marquis 2. Not too impressive lumen wise, lol.
Mr. Fixer, I see you picked up that blue Keymate, very nice!! They look much better in your pics than they do on the auction sites.
bykfixer
My own little Idaho
Forgot about these....
Lift'd commented he wanted a keymate incan. I showed him a link to the blue one in the pic above. He said "nah", so I put in a bid and won it.
The Nano is about 3x as bright as the incan Keymate. The Keymate LED is amazing for it's size.
LiftdT4R
NJ / PA
I think there are some folks on here running extensions on 6Ds that turn them into like 10Ds if I remember right. I've never forked over the cash for the extensions on fleabay but that would be one heck of a light!!
I scored another 7C but man is it rough. Gonna take some work but I'm hoping to have some pics soon.
Guitar Guy
West Virginia
Cool on the 7C. Yea, I saw those extensions but didn't think they seemed worth the $. I did order one of those lanyard ring end caps for the pre letter Mags. It was reduced to $18+, so I figured it could be interesting to experiment with.
JT
bykfixer
My own little Idaho
Good score on the tailcap.
A Maglite lanyard ready tailcap with some other approaches.
- Left is what GT Price owned LA Screw eventually used. They mounted a stud onto the tailcap with a hole drilled for a split ring. Don Keller did that in the Kel-Lite days before GT Price owned LA Screw.
- Next to that, what Maglite did. They used a very sturdy C hook poked into holes like many companies did early on in history. The original idea was a nail hook, but Maglite took it a step further.
- LA Screw began with a hole drilled in a cap that fastened over a tailcap. You slid nylon cord through the hole and tied a square knot to keep it attached. The square knot was larger than the hole and viola...
- Finally, a bykfixer approach where a 90° hole is drilled using the outside edge of the cap. 1/8" deep from right angles using a 5/64" drilled bit and a camera wrist lanyard on a spare tailcap from an ML25 that was damaged beyond repair.
Most here use paracord of some sort for wrist lanyards. I use old style SureFire type of wrist lanyards that can be found in bulk for about a buck each. But adding a lanyard to an old Maglite is an old twist that never really caught on. The lanyard ready tailcaps are getting scarce.
L to R
2015 Streamlight Nano
1980's 2D Maglite
2015 Streamlight Keymate
- The Nano is great for sudden lights out in a building and you need to find an exit.
- 2D... well that one has a rich history that many think revolved around police. The 2D was more of a household light. The 3D and beyond were more suited for duty lights.
- The LED Keymate is a very capable little light that has enough throw to use for searches inside a darkened barn or building. Coin cells don't hold much fuel though.
Guitar Guy
West Virginia
Great photos byk. Thanks for the explanation of the end caps, and good idea with drilling the hole.
Cool tiny lights too. Yes, the 2D and 3D incan workhorses. I used them for a couple of decades as a Realtor showing houses when there wasn't much else commonly available.
Byk, I wouldn't mind seeing some more of those LA Screw lights. Liftd mentioned them to me. Do you have many examples of their different models / time periods?
I have a paracord knot that I tie around the barrel and when it's 100% tightened, it stays put and does not slip, but yet it can be loosened and moved to another light and re-tightened. I've been telling Liftd about this, and finally got some pics of it.
The important part is the slip knot around the barrel. After that, you can use any kind of fancy knots or methods to make a belt loop or wrist loop. This was a quick one. I don't know what it's called, but it's kinda like a hangman's noose without the lug that snaps your neck. When it's tight, it takes quite a bit of effort to even spin the whole thing on the barrel. I don't always like a wrist loop, but sometimes I do. It can be used in either hand position as shown.
I'm going to fashion one and connect the other end to the lanyard cap when it arrives, kinda like a handle on a thermos bottle. I got some cool yellow cord with a snake pattern that I want to make something out of for that purple 2C I just got.
JT
[/IMG]
[/IMG]
[/IMG]
[/IMG]
bykfixer
My own little Idaho
Lovin' the loop idea. And the upcoming thermos handle idea. Did you come up with that or did you see it from an old school source like your grandpa or something?
Speaking of old school;
Yeah I could place all 3 or 4 of my LA Screw type of lights on the carpet for a family photo but instead...
http://www.candlepowerforums.com/vb...e-vintage-California-cop-light-company-thread
Here's a history of a few 1970's game changers thread with lots of stuff many did not know that is now chronicled by a few CPF members and quotes from the actual players in the game back then.
http://www.candlepowerforums.com/vb...-Don-Kellers-last-hurrah-the-Brinkmann-Legend
A thread about one of Don Kellers last ideas
http://www.candlepowerforums.com/vb/showthread.php?272627-The-ABTOMAT-Police-Flashlight-Collection
And possibly the worlds best cop light collection.
Most of the photos can be seen by clicking on that annoying photobucket icon.
Edit: Well today clicking on the icon is not working for me. But right click, open in new tab and looking at the 'new tab' still works.
The other day images fixed with ~original added to the link had stopped working. Today they are working again.
Weird.
Point being JT is that many of the photos are not gone, you just have to do a work around to see them.
Nother edit: the photobucket pix work again (6/3/18) but who knows for how long
End nother edit.
Guitar Guy
West Virginia
Great pic Ven.
Thanks for the links byk, I'm going to look through them this eve.
I came up for the idea for the paracord loop after I started fooling around with knots. I had been trying to think of a way to make something for a Mag, and once I found that knot that stays ultra tight, I just thought about it until I came up with that.
Thx for the info about the photos, I had looked at a few threads that I couldn't see the pics on.
JT
LiftdT4R
NJ / PA
I am digging those knots! Makes me want to order another UCP Incan from Mag on clearance just so I can do the same combo. Do you have any links on how to tie them?
Guitar Guy
West Virginia
Unfortunately Liftd, I don't have anything yet to show how to do that slipknot around the barrel. I learned it a long time ago, and don't even know its proper name. It's pretty simple and effective after you tie it a few times. I tried to do a pictoral sequence of a couple different knots, but it's too hard to hold the knot and take the pic with one person. I'll have to work on another way.
I was able to get a few pics of the Marlinspike Hitch that I wanted to show you guys. It's a super easy and quick old shipmate's knot that allows you to use a stick, or, yes, a flashlight :drool: as a T-handle for pulling on a rope, or to make a ladder if you have two ropes. It's pretty easy to look up, and I've seen about 4 or 5 different ways to tie it, but I tried to point out a way that is simple and easy to remember when first learning it, and kind of leads you into tying it other ways. It takes about 3 seconds if you already have the flashlight in your hand.
I'll try to post the steps in the general section when I get time. I think a lot of people will get some use out of it.
JT
[/IMG]
magellan
Honorary Aussie
USA
This is more of a width of the head rather than a length relationship. This shows the big 20k lumen mule from Vinh compared to the little Nucleus watch battery light light from George, shown with their batteries. The little Nucleus is about 1/8 inch in diameter vs. just under 3 inches for the Vinh. If my memory serves me the Vinh was a Tk75vn77.
So the size difference is about 2 7/8 inches.
http://imgbox.com/ORtnd0fE
magellan
Honorary Aussie
USA
Haha! Ya sure wouldn’t want to accidentally sit on the big one!
bykfixer
My own little Idaho
Can't see in the pic, but a worker to the left is using a handheld flashlight to aid in checking for complete coating in crevices of the worlds largest flashlight before setting it into place.
