<BLOCKQUOTE><font size="1" face="Verdana, Arial">quote:</font><HR>Huh? Are you sure about your calculations? 123As according to Energizer have 98% the capacity of their AAs (only a small difference).<HR></BLOCKQUOTE>
I got data from
data.energizer.com
Here is the calculation:
energy = watt hours = Volts x (Ampere hours)
123A lithium
energy = 3.00 x 1.300 = 3.90
AA alkaline
energy = 1.50 x 2.850 = 4.28
So ratio of 123A to AA = 3.90 / 4.28 = 0.91
Now there are a lot of assumptions going on here, some of which would never occur in real life (constant voltage).
<BLOCKQUOTE><font size="1" face="Verdana, Arial">quote:</font><HR> Also when we step up to the Luxeons, the current draw is now significantly higher, so 2x 123A should last longer than 2x Alkaline AAs, even the more expensive high-current varieties (Duracell Ultra, E^2). <HR></BLOCKQUOTE>
This is very true for high current devices. If you are draining a battery in 1 hour, you need lithium (or NiCad etc.) If you are draining a battery in 4 hours, a Duracell or Energizer alkaline can keep up. If the current draw is significantly less, the Ray-O-Vac wins! (based on other CPF members data).
<BLOCKQUOTE><font size="1" face="Verdana, Arial">quote:</font><HR>123A also have a much flatter discharge curve and will give a brighter light for longer while the AA alkalines will drop off.<HR></BLOCKQUOTE>
True in most flashlights, but as barbarin mentioned
<BLOCKQUOTE><font size="1" face="Verdana, Arial">quote:</font><HR>Regulated. Yes, of course is the best way.
This way we can use different brands and types and get the same light output.<HR></BLOCKQUOTE>
Now my personal experience is that lithium cells are great, and numbers like the above don't do them justice. I think that a Li AA is about twice as valuable as an alkaline, not '1.02'
Since the TESTED runtime of the circuit (a much more important number than anything theoretical) is 8 hours at full brightness then alkalines should work fine I think.
(if I made any math errors someone please correct them...)
