Features
• CREE XP-G (R5) LED
• Highly effective current circuit board
• 3 brightness levels
• Active dimming system with auto-adjust function
• Soft turn-on mode and low illumination for everyday usage
• Convenient one-handed operation
• Board voltage circuit, compatible with primary or rechargeable Li-on batteries
• Reverse polarity protection.
• Equipped with integrated lens
• Constructed from aerospace grade aluminum alloy
• Type III military grade hard anodizing
• Special-made rhombic knurling for better grip
• Waterproof in accordance with IPX-8 (2 meters submersible)
• Tail stand ability
ON/OFF
Turn ON: Rotate the head of the flashlight in a clockwise direction to turn it on.
Turn OFF: Rotate the head of the flashlight in a counter-clockwise direction to turn it off.
Brightness Control
When the flashlight is turned on from off:
• Flashlight will enter high output level when the head is parallel to the floor
• Flashlight will enter medium output level when the head is at 45 degrees
• Flashlight will enter low output level when the head is pointing straight down
Notes:
1. Each time you turn on the flashlight, the SENS Mini built-in acceleration sensor can detect the angle and switch to the appropriate brightness level
2. After the lights is powered on, the sensor will shut off to avoid brightness changing when the user changes the flashlight angle.
Active Dimming Technology
With the flashlight switched off, turn on the light with the head pointed straight up. The light will access the active dimming function immediately. An acceleration sensor is built in the SENS Mini flashlight, which can continuously detect the angle of the light and work with the light’s mico-computer to select the appropriate output. For example, when it detects a parallel position, the built-in micro-computer will assume a higher output is appropriate and increase output to illuminate a longer distance. When it detects a vertical position, micro-computer will decrease output so to save battery life, extending runtime of SENS up to 5-8 times.
Notes:
1. When the flashlight switches from low to high level, the output will increase momentarily, allowing the user to observe distant targets.
2. After the flashlight switches from low to high level, the brightness will decrease slowly to allow the user’s eyes to adapt.
SENS AA
LED: Cree XP-G R5
Battery: AA (NiMH, Alkaline, Lithium), 14500 Li-ion, LiFeP04
6lm (60h), 20lm (12h), 120lm (2h)
700cd (max distance 53m)
81mm (length), 19.8mm (head), 17.5mm (body)
Weight: 26g
IPX-8 (2m)
SENS CR
LED: Cree XP-G R5
Battery: CR123A, RCR123A (16340) Li-ion
20lm (27h), 60lm (6h30m), 190lm (2h) (1550mAh SYSMAX CR123A)
1450cd (max distance 76m)
64mm (length), 19.8mm (head), 19.8mm (body)
Weight: 23.8g
IPX-8 (2m)
SENS Mini
LED: Cree XP-G R5
Battery: CR2, RCR2 (17335) Li-ion, LiFeP04
20lm (14h), 50lm (4h), 170lm (1h) (850mAh CR2)
1200cd (max distance 65m)
57mm (length), 19.8mm (head), 18.5mm (body)
Weight: 19.4g
IPX-8 (2m)
more pics coming
high res pics here
http://indafoto.hu/autoart/jetbeam_nitecore
