Re: Why Does My PILA only Charge to 4.17 volts?
After all the raves about Pila here and paying more than twice what the WF-139 cost I am disappointed. Owner after owner find the same flaw - charging less than the optimum 4.2 volts so it isn't my multimeter. Although the charging algorithm isn't optimal somehow my WF-139 always charges to 4.20 volts. You would think Pila could calibrate them properly or include some sort of manual calibration capability.
OK, I think I understand your disappointment. Let me cover a few points that will perhaps allow you to feel better about your Pila.
First, I wouldn't say that charging to less than 4.20 Volts is necessarily a flaw. The Magic "4.20 Volts" isn't really magical at all. It is merely the center of the 4.20 +/- 0.05 Volt charging specification. Charging to less than 4.20 Volts allows more cycle life of cells at the cost of reducing the charge by a few percent. Charging above 4.20 Volts reduces cycle life, but allows a few more percent capacity to be obtained. 4.20 Volts is just the middle ground here.
Second, as Lite_me mentioned, a charger that uses a proper algorithm, but with a fixed charge rate cut off, such as the Pila utilizes, will not charge cells of different capacities, all to the same voltage. The higher the capacity of the cell, the higher the end voltage will be. The lower the capacity of the cell, the lower the ending voltage will be. This is a result of having a fixed charge rate cutoff point, as opposed to a variable one, such as a hobby charger utilizes.
A third point, a charger that forces the cell to a certain voltage before terminating the charge, rather than utilizing the 0.1-0.03C CV cutoff of a proper algorithm, such as the WF-139, abuses the cell and shortens the cycle life. As I jokingly referred to in another thread, this could be seen as an advantage, as it speeds up the death of cells that are in suboptimal condition, and forces you to buy new ones sooner.
Note also, that while the Pila's fixed cutoff is a departure from the proper algorithm, it usually falls within the 0.1-0.03C range, for most cells that it is used to charge.
One final note, when using a charger which utilizes a proper algorithm, as cells age, the end voltage will gradually become lower, as the IR of degraded cells won't allow the cell voltage to reach the same level as when the cell was in better condition. I look at this as being a handy feature, as it is an additional way you can guage the condition of your cells. This is something that when using a charger such as the WF-139, you will not be aware of, as it will allways charge the cell to the same voltage.
I hope these comments allow you to look at your Pila in a different light. As I have said before, I don't own a Pila and never have, but the information available here on the Forums is sufficient enough, for me anyway, to recommend it over most other consumer type chargers out there. Hopefully this will change, competition is a good thing for everybody, but really I think you made a good choice.
Dave
