pila for 123's
HiKing808
can anyone point me toward where to buy ready made spacers for the pila ibc charger for cr123's i'd like to just purchase it and plug it in without any modifications.
AW sells spacers for $1.75 with the purchase of cells. You can also use a ball bearing like in this photo. IIRC you can even used appropriately sized nuts and bolts or a stack of coins tapped together. There are also some other things that can be used but I can't find the thread that had the different suggestions. I assume you can use anything conductive as long as it does not have a lot of resistance. I can't comment on the how well some of these improvised methods work, I just read about them. I personally use spacers from AW.
EDIT
Here's what Silverfox uses.
Here's a thread regarding coins.
if i go with the nut and bolt like silver fox, is their any type of material i should be looking for, or stay away from??? looks like maybe copper is the best is this right???
