Klem
That's and interesting plug and it looks like it will work. Where did you source it from? Stainless steel?
If you want to play it safe you can go down without a battery in the canister for the first dive. Or even knock-up a quick-n-dirty second canister without gland to test that plug. Don't need to waste a good dive to test it, just fill it with weight and drop it from a boat, bridge or a wharf into the water attached to a piece of cord. Or sit it in a bucket of water for a day or so without depth pressure.
That wing-nut can be replaced with a couple of normal nuts if you want to keep clean lines on the canister (no snagging or accidental opening underwater). Your canister is a bit long to sit in a BC pocket so that wingnut will be sitting out waiting to get caught on something...and it will! Obviously have a small wrench above the surface in your gear to open it. Or you could use an ABS press-fitting end-cap over the end of the canister to protect the wingnut, drill a few small holes in the cap to prevent any unwanted buoyancy.
Have the gland coming in from the other end, not the side. Your battery is triangular so there will be space in the canister to run the leads to the plug end.
