Flash_Gordon said:Dielectric means non-conducting. Probably no place for this on a flashlight since most lights use the body threads for a conducting path.
Mark
FlashKat said:Dielectric grease is conductive since it is used on battery connections, spark plug wiring, etc. There should not be a problem unles it swells up your o-rings. It helps prevent corrosion.
Minjin said:It is NOT conductive. Thats what dielectric means. Where there is a metal to metal interface, the grease is pushed out of the way. You grease these contacts so that they are always protected from the elements. Every spot other than the actual contact is still coated.
Conducting grease has too much potential for disaster.
FlashKat said:Okay...I am wrong as it is non conductive, but it is not a true insulating grease where it still works when applied to flashlights. I was thinking something different since I do use it on my car battery terminals. I like this stuff.
Minjin said:You're still not getting it. Get some hair gel or something gelly. Put a little swirl on your index finger. Now bring your index finger and thumb together in a pinching motion. Squeeze down all the way. Your fingers are now touching. The gel/grease has been pressed out of the way. If you could press down hard enough, when you pull your fingers apart, there would be no grease between them. The same exact thing happens with spark plug terminals, electrical connections, and yes, your flashlight threads.
It IS insulating in that it does NOT conduct electricity.
