PLEASE help me with the D2flex manual...
toby_pra
Germany
Hello! :candle:
Yesterday i received a light with a D2flex direct drive controller.
I also have the users manual, but caused by my bad English i really have
a problem with understanding it. :crackup:
This D2flex gives me the opportunity to have several UI's and to change
between them. BUT I DONT KNOW HOW TO CHANGE!!! :candle:
At the moment there is a UI with dimming used. I dont like that dimming
and would like to change to another UI with several brightness levels, without strobe and SOS...
Can you please help me?:wave:
schick mal 'nen PN, ich kann es dir teilweise übersetzen.
(send me a PM, I will translate parts).
it's in UIB2 or UIB2Q, so:
If you are in UIB2 mode, then to access the menu system you must remove power (disconnect the
battery) from the circuit and then re-apply power. A dim, rapid flash sequence from the LED will
indicate that the "Menu entry window" is open (the window is open for three seconds). Within 3
seconds of applying power PRESS (not click) the switch and the LED will flash brightly 2 times, then
stay steady dim to indicate that the Menu system has been entered.
Note: During the 3 second "Menu entry window" and while in the Menu system, temperature sensing
is disabled to allow access even if an over temperature condition exists.
--> Stromlos machen, dann wieder anschliessen; Drück den Schalter in den ersten 3 Sek.
If you are in UIB2Q mode, then to access the menu system you must remove power (disconnect the
battery) from the circuit and then re-apply power WHILE keeping the switch pressed down. The LED
will flash brightly 2 times, then stay steady dim to indicate that the Menu system has been entered.
ausschalten, während des wiederanschliessens Schalter gedrückt halten.
Make sense?
Bret
When i chose the first option UIB2 the LED flickers on time, when
i connect the power again. as you described. Bute when i press the switch
within these 3 seconds, there happens nothing no flashing 2 times...:mecry:
I have already tried...
But what should happen, when i press the switch after conecting the body
with the head and the led flashes shortly. Should i so change the UI?
