So one of those 18V drill batteries is a no go?For a car, sure! For a bike, not so much given you'd need one hell of a battery pack to drive those.
Ok, You got me feelin like it can be done with haveing to lug twenty pounds of batteries around. Please tell me how you would go about building the batt. pack. Thank you for putting up with my questions.Other than the price,
The emitter is an SSC P7, running at 750Ma. The driver is a buck-boost, fully internal, and operates from 9 to 50 volts. The optic is SSC's own spot optic for the P7. It sounds like the spot optic is a 20deg fwhm, and it's TIR, so the efficiency ought to be over 90%.
They use Deutsch connectors, so compatiblity is not an issue. They're going to be selling a battery pack for it next month, and there's no reason at all not to build your own pack.
IF you don't want to build your own light head, it's a build-the-pack and plug it in solution.
Eamon
