Oke, thanks for al the diffrent oppinions, but why ask If seller removes battery and charger? It wil lcost less to ship but then I'm without a batterie and charger, still no working light
Yeah, I'm not sure why removing the battery would be an attractive option. You'd be relying on the current owner to do something that they might not be comfortable doing or that you might not be comfortable with. I'm not sure I'd want someone to partially disassemble the light I was going to purchase unless it was a fellow enthusiast who knew what they were going. Some people aren't even slightly technical or mechanical though. It's also not like the light would be discounted with the battery removed so you'd still pay full price for it then have to take the time to drive somewhere to purchase a battery that would likely be at least the equivalent of $30 at the minimum in the Netherlands.
rufusdufus, The reason that I say it's head and shoulders above the POB is for several reasons. The first being the color temperature. The 4200K color that the N30 provides produces much more eye friendly color rendering and gets the most lumens possible from that 30W ballast. The next reason is because it uses NiMH batteries and a quick change battery pack. These battery pack is lighter and provide much better energy density over the SLA battery in the POB. The N30 has the advantage of the long run LED array built into the handle and thefore makes a great "huricane" light, camping light, or general task light and keeps it all together in one convenient package. It's also great for back-up light when the voltage is too low to run the HID bulb. The N30 is 1/3 the size and weight of the POB which is a huge difference, while the run-time and output essentially remain the same between the two lights. I also feel that the N30 is a bit more rugged than the POB. The plastic seems a bit more pliable or complient and its lower mass make falls more survivable. I've dropped the N30 several times accidentally from 30" to about 5' and it's still hanging in there. The only place where the POB has a
slight advantage is in the category of throw, but then the N30 is no slouch. The N30 also apears to have a better, more reflective surface which limits it's throw disadvantage to the POB with generic reflector.
Below are comparison pictures borrowed from
mtbkndad's Shootout IV thread for comparison purposes.
N30
POB
Imo, the N30 appears to producs at least an equal amount of light if not a few lumens more overall, despite the N30 being down 5W to the POB. This is about the same amount of difference I see between my POB and N30. Frankly, my Costco and POB HIDs have been doing a lot of sitting around because of the N30. The N30 and Polarion's have consistently been my "go to" HID's.
Photos borrowed from the Shootout IV pics, thanks to mtbkndad.
The other reason that I like the N30 in the OP's situation is that he was going to be looking at about $50 for the POB plus $150 for shipping. With the N30 he'd be looking at just the opposite... $150 for the light and $50 for shipping. That's a far better value.
