Pocket Light Recommendations
HystericalFool
____I would like to purchase the light in person from a brick and mortar store. I am located in ______________.
_ X_This will be mail-order or Online (location doesn't matter).
2) Budget: An easy question, but you may change your mind after answering the rest! :)
____I don't know yet
____Up to $25.
____Up to $50.
____Up to $100.
____Up to $200.
____Up to $300.
_X_Essentially unlimited.
3) Format:
____I am not sure, please help me decide.
____I want a flashlight (hand held/self contained).
_ X_I want a self-contained headlamp.
____I want a headlamp with an external pack/power source.
____I want a mounted light (typically for a bicycle or vehicle)
____I want a lantern/area light.
____I want a portable spotlight (it may have an external power source).
____Other ____________________________________________
4) Size:
_X_ MICRO - Keychain size.
_X _TINY - Every day carry (2-4 inches).
____SMALL - Every day carry (4-7 inches).
____MEDIUM - Holster/belt ring carry. (>7 inches)
____LARGE - Big enough to need its own travel case.
____I don't know/I don't care.
5) Emitter/Light source:
_X _LED (known for efficiency, longevity, and compactness)
____I don't know.
6) Manufacturer:
_ X_I want to buy a light from a large/traditional manufacturer that is ready to go out of the box.
____I would like a light from a specialty manufacturer (Possibly limited run/Custom).
____I am interested in assembling my own components. (for example a "host" or flashlight body from one manufacturer, and a "drop-in" emitter from another source).
____I intend to use "Primary"/Disposable Alkaline batteries based on the usual AAA/AA/C/D sized cells common to most stores.
_ X_I intend to use "Primary"/Disposable Lithium batteries based on the usual AAA/AA/C/D and CR123 sized cells common to most stores (often a cold weather or long storage choice).
____I intend to use Rechargeable cells (NiMH or NiCD) based on the usual AAA/AA/C/D sized cells common to most stores.
____I intend to use Rechargeable cells based on less common formats (18500 or 18650 Li-Ion, RCR123, et-al).
____I want a light with an integrated rechargeable battery pack.
____I don't know/I need more information on power sources.
8) How much genuine out the front (OTF) light do you want/need?Sometimes you can have too much light (trying to read up close up with a 100 lumen light is not a happy experience).
____I want to navigate a dark room or read a map (1-10 lumens).
____I want an indoor "blackout" light (15-50 lumens)
X I want to confidently walk around an unlit/unpaved rural area (60-150 lumens).
____I want to illuminate my entire backyard or a campsite (150-300 lumens).
____I want to illuminate an entire field, the neighbor's front yard several houses down, impress my friends and neighbors, etc. (300-700 lumens).
____I want search and rescue type illumination (800+ lumens).
____SPECIAL NOTE: Burst/Turbo mode Category - There are several lights that will run at a super bright maximum for a very limited period (usually 5-10 minutes) and then will "step-down" to a lower level for thermal control. Check here if this is acceptable.
_X_ All Flood: I am doing "arms length" tasks like reading and campsite cooking.
____Wide Flood: I want a defined flood area for semi-close tasks like after-dark campsite tasks or working on a car.
____Narrow Flood: I want a sharply defined flood area that will project some distance for tasks like trail walking.
____Wide Throw: I want a beam with a noticeable hot-center for distance throw and a significant amount of "side-spill". Good for rough trail hiking, search and rescue, and general distance work.
____Narrow Throw: I want a beam with a very tight "hot center" and minimal "side-spill". Good for distance viewing, fog, and looking through dense undergrowth.
____Turbohead: I want a far-distance projector with a sharply focused spot of light and minimal or zero side-spill. Good for extreme distance and impressing your friends.
9a) Distance: How far away will you typically need to see with this light(check all that apply)
____Less than 1 yard/meter (reading, other close work)
_ X Less than 5 yards/meters (looking for something inside a dark shed/garage/basement)
_ X_5-20 yards/meters (check out a noise in the backyard)
____150+ yards (I am searching from a helicopter)
X 30-60 minutes (I have plenty of batteries just ready to be changed)
____90-120 minutes (Runtime is moderately important, but still not critical)
____3 hours + (I critically need this light to run on max for extended periods in between battery changes/charges).
____Not Important (A "night-stand" light).
_X_ Very Important (Camping, Backpacking, Car Glove-box).
_X _Critical (Police, Fire, Search & Rescue, Caving, Survival).
____I don't know.
____Any size switch will do.
____I need a BIG switch (I'll be using gloves or have very large hands or coordination issues).
____I want a forward clicky (Helpful for momentary activation and signaling).
____I want a momentary switch (Predominantly for use with signaling and short bursts of momentary light only).
____I want a body mounted switch (near the head, like on a Maglite).
_ X_I want a tail mounted switch (found on the majority of today's high end lights).
____I want a remote switch (usually found on high-end bicycle headlights)
____I don't care.
____I don't know.
____A simple on-off with only one output level is fine for me.
_X _I want 2 light levels. (Brighter/short runtime and Dimmer/long runtime.)
____I want multiple light levels. (Some lights have 5-16 light levels.)
_ X_I want a selector ring.
____I want a strobe mode. (Oscillating pattern to confuse/blind aka "Police Mode")
____I want SOS mode. (blinks in ---...--- emergency pattern)
____I want a beacon mode. (Regular flashes at full power to show location.)
____I don't care.
____I don't know.
14)Material/Finish/Coating
_ X_Anodized Aluminum – either type II or III (Hard Anodized) (Aluminum, specifically HA, is the most common material/finish for today's higher end flashlights).
____Stainless steel (durable, but much heavier than aluminum)
_ X_Titanium (durable and nearly as lightweight as aluminum, but can be moderately to significantly more expensive).
____I don't care.
____I don't know.
15) Water resistance
____None needed
____IPX4 (Splash resistant)
_X _IPX7 (Waterproof to 1 meter/30min)
_X _IPX8 (Submersible to greater than 1 meter for 4 hours)
16) Storage conditions
____In house (temperature/climate controlled environment)
____Emergency kit (long standby periods)
____Automobile glove-box (wide temperature swings, long standby periods, critical reliability)
_ X Other_____________Pocket Carry____________
____"Hybrid" light (bright incandescent combined with long running LEDs)
X Pocket/belt clip
____Holster
____Wrist/Neck Lanyard
____Crenulated bezel
____Non-sparking, Intrinsically Safe (IS) for use in explosive environments
For an AA i will throw 2 lights in
D25a ti and the thrunite 10s
No control ring though,sunwayman do some with control rings.Maybe worth checking some of their lights out:D
I'm a bit confused as well. Are you looking for a headlamp? If so, most of them are floody. Can't go wrong with a Surefire, but there are brighter and/or lighter headlamps out there.
If not, then you still have lots of options. In addition to the fine lights listed above, consider the Nitecore SRT3. It ticks off most of your boxes: tail switch for on/off including momentary on; variable control ring for infinite adjustability of output; small; floody; pocket clip; runs on AA or CR123 batteries, take your pick. Sunwayman VR11 and JetBeam RRT-0 are similar.
Lots of nice custom titanium lights out there as well :)
I saw the recommendation template, after I already created the first thread. I'm new, I don't know how to contact the moderators.
I am looking for a handheld pocket-sized flashlight. It was a typo.
For CR123A type lights, I have the EagleTac D25C Ti clicky, the Sunwayman V11R and M11R (had the V10R for a year,) and the ShiningBeam I Mini.
There are also the FourSevens lights, the JetBeam lights, the Olight lights and the Klarus lights that you can look to, as well, in your research.
Chris
Another vote for Eagletac D25 to series they come in both AAA and CR123 version.
