pocket light
cityevader
San Jose, CA
Another recommendation needed for co-worker to supplement the lower output Pelican 1920 penlight, with main concern being ON/OFF only without modes, however, he isn't averse to a twist head that can be locked in a position, or variable output twist head. And not a cr123 light. an 18650 (or other li-ion) light is ok, or ni-mh...so somewhat small to fit in front pants pocket.
____I would like to purchase the light from a brick and mortar store. I am located in ______________.
__x__I will be mail-ordering or buying online, so this doesn't matter.
2) Budget: An easy question, but you may change your mind after answering the rest! 🙂
____Less than $25.
____Less than $50.
__x__Less than $100.
__x__Less than $150.
____Less than $300.
____I have no limit.
____I’m flexible, tell me what you gotJ.
____Other, please specify ________
3) Format:
__x__I want a flashlight.
____I want a headlamp.
____I want a lantern.
____I want a dive light.
____I want a portable spotlight.
4) Flashlight-specific format/size:
____Keychain size.
____Every day carry small (2-4 inches).
___x_Every day carry medium (4-7 inches).
____Holster carry.
____Big enough to need its own travel caseJ.
____I don’t care.
____I don’t know.
____N/A
5) Emitter/Light source:
__x__LED (known for efficiency, longevity, and compactness)
____I don't know.
6) Manufacturer:
__x__I want to buy a light from a traditional mass producing manufacturer that is ready to go out of the box.
__x__I would consider getting a light that is pieced together (for example a “host” or flashlight body from one manufacturer, and a “drop-in” emitter from another source). Under the right circumstances, this path can provide more options to the consumer to meet specific needs, and can often be easily upgradeable as technology improves.
7) What battery type do you want to use?
__x__I intend to use alkaline batteries (AAA, AA, C, D) (disclaimer, while it does not preclude all choices, these are not recommended for many of today’s most powerful lights)
__x__I intend to use rechargeable nickel chemistry (NiCad, NiMH, NiZn)
____I intend to use lithium primary batteries (CR123, CR2, Energizer Advanced/Ultimate Lithium AA/AAA)
__x__I intend to use rechargeable lithium (li-ion) chemistry. Feel free to specify a size if you know which size you want (14500, RCR123/16340, 17500, 17670, 18650, etc.)
____I want a light with an integrated rechargeable battery. (Note: these choices may be very limited unless you are looking at spotlights)
8) How much genuine out the front (OTF) light do you want/need? Sometimes you can have too much light (trying to read up close up with a 100 lumen light is impossible).
____I want to navigate a dark room or read a map (0-10 lumens).
__x__I want to walk around an unlit rural area (50-150 lumens).
__x__I want to illuminate my entire backyard or a campsite (150-300 lumens).
____I want to illuminate an entire field, the neighbor's front yard several houses down, impress my friends and neighbors, etc. (300-700 lumens).
____I want ridiculous amounts of lumens (800+ lumens).
9) Throw vs. Flood: At what distance will you be most likely to use this light? Select all that apply.
____Less than 1 yard/meter (reading, other close work)
__x__Less than 5 yards/meters (looking for something inside a dark shed/garage/basement)
__x__5-20 yards/meters (check out a noise in the backyard)
____150+ yards (I want maximum throw possible)
10) Runtime: Not over-inflated manufacturer runtime claims, but usable brightness measured from first activation to 50% with new batteries (Measured on maximum output).
__x__30-60 minutes (I have plenty of batteries just ready to be changed)
____90-120 minutes (Runtime is moderately important, but still not critical)
____3 hours + (I critically need this light to run on max for extended periods in between battery changes/charges).
11) Durability/Usage: Generally the old phrase “you get what you pay for” is very accurate for flashlights.
____Not Important (A “night-stand” light).
_x___Very Important (Camping, Backpacking, Car Glove-box).
____Critical (Police, Fire, Search & Rescue, Caving, Survival).
____I don't care.
____I don’t know.
12) Switch Type and location (choose all that apply):
__x__I want a forward clicky (Helpful for momentary activation and signaling).
____I want a momentary switch (Predominantly for use with signaling and short bursts of momentary light only).
____I want a body mounted switch (near the head, like on a Maglite).
____I want a tail mounted switch (found on the majority of today’s high end lights).
____I don't care.
____I don’t know.
__x__A simple on-off with only one output level is fine for me.
____I want multiple light levels. (Some lights have 5-16 light levels.)
____I want a selector ring.
____I want a strobe mode. (Blinks to show location.)
____I want SOS mode.
____I want a beacon mode.
____I don’t care.
____I don’t know.
14)Material/Finish/Coating
__x__Anodized Aluminum – either type II or III (Hard Anodized) (Aluminum, specifically HA, is the most common material/finish for today’s flashlights).
__x__Stainless steel (durable, but much heavier than aluminum)
____Titanium (durable and nearly as lightweight as aluminum, but can be moderately to significantly more expensive).
____I don’t care.
____I don’t know.
15) Special Needs/extras: Is there anything else you want or need that hasn't been mentioned? Select any below.
____“Hybrid” light (bright incandescent combined with long running LEDs)
____Pocket/belt clip
____Holster
____Wrist/Neck Lanyard
____Crenulated bezel
____Non-sparking Intrinsically Safe (IS) for use in explosive environments
Leaning a bit more towards power, such as an 18650- roughly 150lm light or even a 3AAA within an adapter for a similar size of roughly 5 inches or thereabouts.
The penlight Pelican 1920 would serve the role of the above mentioned lights, and his "pocket light" would be his go-to for more power.
It just gets tricky with only on/off w/o modes in terms of choices.
So not too big he couldn't fit in in front pants pocket, but more power and throw than penlight.
A lego light of misc parts would be ok as long as a list of individual components is given.
Sunwayman V20A or M20A? tail clickie with variable output ring at the head. Go for the M10A or V10A for the 1 AA version. Jetbeam's RRT-0 also has a tail switch and a selector ring.
Does a side switch on the head work? Fenix's LD22/LD12 have a main tail clickie, and a side switch of modes.
What about a dual tailcap clickie? Main switch for on/off, side switch for modes (Klarus's lights)
Is a side switch ok?
Ooo, that RRT-0 may just be the ticket! May be just the right compromise for him.
Since it can take an rcr123, can I safely assume that with the AA extension and an approriately-sized li-ion A) would be perfectly safe B) it should get plenty of power/runtime?
Yes, RRT-0 can run on 14500 with the "AA" extender ... but runtime (& power) will be the same as RCR123A. Both are 4.2v (at 100% SOC), and both typically have approximately 750 mAh.
gotcha...didn't realize that.
It still is a valid option though if the larger size is desired in conjunction with higher output.
Just ordered one about about 12 minutes ago! The RRT-0 that is.
I'm going for my usual recommendation, Fenix E11. Hard to beat for the money and fits virtually all of your requirements. It's advertised as 105 lumens max but it easily matches a couple of 150 - 160 lumen lights I have. Built like a tank, reliable and simple to use, plus it has a very nice quality of light, not too blue or yellow.
