Pocket Radio Query
I had a KA390 until D cells took a dump. Like a dummy left it loaded during non use. It is a good radio for the money. Antenna extends almost 3 feet.
@knucklegary perhaps you're aware of this, however JIC you or someone else isn't...one solution is use AA to D cell parallel adaptors and rechargeable NiMH or Lithium based cells (which have a true 1.5v output). I did this in several applications with both C and D adaptors. It's save us a lot of money over the years and also we've had no leak damaged electronic appliances. Just a thought.
I did experience e-skip back in the late 1990s. 96.5MHz from Houston TX, some 850 miles away, was blocking my reception of Power 96 Miami ~100 miles away. It was pretty wild. Both our local engineers and the Houston station's engineer were quite surprised and had some fun conversations about it. I also swapped their engineer a bunch of our stations' swag for his, along with airchecks recorded of the event.
That would have been received on a rack-mounted Sony ES (XR-530?) car radio, with a whip antenna on the peak of the 1-story house.
I had an 8 C cell boom box that the kids would run on batteries instead of plugging it into a nearby outlet. When I went to use it the batteries were dead.
I decided to replace the batteries, but put small pieces of carboard between the battery contacts and the unit's springs. That way there were always fresh batteries stored in the unit for emergency use. The kids just thought that the batteries were dead, and plugged it in whenever they wanted to use it.
I don't know if thin cardboard (like from a cereal box) would protect from leakage damage, but I suppose wrapping the ends in plastic wrap would. Alkalines hold their charge better than LSD NiMH batteries, so I don't mind using them.
Another to look for is the icom ic-q7a. Its an r2 with a v/u transceiver grafted in. Some easy hacking and it does dc-daylight on 2 aa batteries. 100khz-2.4ghz am fm wfm. Receives days on 2 aa cells. And does 2m,70cm,frs,gmrs,murs,weather. Can be found at hamfests for $20 if you watch.
WARNING: Highly caffeinated post to follow 😁. Also, I do not wish to turn this thread. The batteries and their usage I discuss below can be used in pocket or emergency radios. I am not attempting to segue into a flashlight discussion. I am also not an expert on anything (just ask my wife 😉). Most of what I've learned has been through the assistance of many fine folks right here at CPF, I'm just sharin' the wealth.
@Poppy good idea using the cardboard. Eight C cells is a lot of batteries to keep going through. Many years ago, we picked up a Streamlight Waypoint spotlight. It takes four C cells. With letting the dogs out several times in the dark each day, we went through them like water (we're rural, "in the woods"). I picked up some Eneloop AA to C adapters, four AA NiMH batteries, and a La Crosse BC700 charger (all on the advice of folks here). It really paid off big time.
I've been lucky with leakage so far. I use Energizer primary cells in things I do not use frequently, like emergency flashlights. These I check every so often and they're stored inside so there's little temperature variances, no extremes, and they don't get bounced around. These batteries will stay charged for many years.
In often used items, like radios and a couple of our flashlights/spotlights, et cetera, I use secondary cells. This has saved us a lot of money over the years and they've more than paid for themselves, many times over.
Were I to keep a flashlight in my vehicle, I'd either use Energizer Ultimate Lithium batteries in it or, as my son does, store the batteries out of the unit. In our very cold winters, the alkaline cells usually go dead as my son found out. I am of the opinion that, for an old school type vehicle flashlight (or portable emergency radio), the way to go is Energizer Ultimate Lithium batteries, in adapters if necessary.
Of course, in the last few years, I've discovered Li-ion cells, mainly of the 18650 type. These and the lights that use them are amazing. Our daily use light is a Wuben L50 and that's replaced the big honkin' Streamlight. What I said in the above paragraphs is how I handle all our old technology items. Now, I am sold on these Li-ion units. All of this I learned here over the years. So, hopefully what I said above may help someone else.
My ft-817 and 818 cover vhf hi recieve.
Weather being 162.400-162.550
Unless you have modified your radios, I assure you that none of the 817 or 818 models are capable of receiving NOAA Weather Radio.
The images attached are the specifications from Yaesu for the FT-817ND and the FT-818ND.
Greetings. Recently, I got a bee in my bonnet to get a small, pocket type radio. What I'm looking for is an AM/FM/Weather unit with a plug for an earpiece (a jack for an external antenna would be icing on the cake). Obviously, reception would be the main concern. Does anyone know anything about these radios? Is there a forum dealing with these types of radios (if so, I didn't find it)? Any help would be greatly appreciated.
Here's an example of what I'm talking about: Kaito KA210 Pocket AM/FM NOAA Weather Radio
A bit more expensive than a Kaito, and a bit larger (more coat pocket sized) is the C. Crane Pocket. It is a FM, AM, Weather band radio that comes with a pigtail antenna for FM and WX. It comes with a pocket clip too.
Another solid radio is the Sangean DT-800. A little different in the controls it has. But it has the bonus of having a bass boost switch. It also has a pigtail antenna for when you don't use headphones. There's a weather alert function too.
I own both radios and like them both. You can't go wrong with either one. They run forever on 2 AA cells. Batteries can be recharged in the DT-800, not sure about the CC Pocket (I usually charge my cells externally).
Another radio to look at that is quite capable and very small, albeit more expensive is the C Crane Skywave 2 and Skywave SSB 2. I have owned the SSB and SSB 2. Both are great radios. It is on the short list for my bug out bag. I take whenever I travel too. The only broadcast band it doesn't cover is LW. But we don't have anyone broadcasting LW to North America anyway. It only weighs a little over 6 ounces. Can recharge NiMH internally and can even get the air band (hence the name). There are two vers of them. One that can listen to single side band and a less expensive option that can't. The older Skywave (SSB) is available if you look around on the used market. But the "2" version has an improved amplifier and speaker. Plus it has an external antenna jack. I love mine and use at home even.
How'd it work out for you?
Sorry, work was definitely not the usual. Didn't get a chance to even turn it on. Will report back tomorrow morning. Thankfully last night everything was corrected at work. Should be significantly less hectic tonight.
Anyone have any long term reliability/durability data on these radios? for something that just has to work in an emergency it would be bad if you find the radio you packed into an emergency kit has biodegraded or been killed by a minor drop. Another warning. dont buy anything with that "soft touch" finish. It eventually degrades into a sticky mess!
I have a Panasonic RF-537 table radio from ???? which hasn't been babied at all and keeps going. I think I picked it up second-hand in the 1990s.
The Sony ICF-19 was built for the 3rd world and feels like it. I bought one last year but they've been in short supply since. The US version is the ICF-506 and is a bit more fragile with the metal grille. Either one would take a reasonable amount of wear. The little Sony ICF-P26 (analog) / P27 (digital tuner, but analog display) and the Panasonic RF-P50 are all nicely built for pocket radios.
