Here is the 1xP7 setting. 1x Driver to 1x LED with 1 battery (or parallel more), Max.2.8A to LED.
Parallel more battery will extend the run-time.
billi, :welcome:
No bad side if wire parallel with protected li-ion ONLY.
No no no for unprotected li-ion wire as parallel connection.
1. yes
2. yes
3. It depends what you need, too many options
eg. 3x li-ion to 2x led, the situation cannot be applied in this case.
kong, the CPU heatsink may need the fan too.![]()
. . . . Any thoughts why this went *poof*? I'm thinking it might be due to LEDs with low vf causing the 7135 chips to work overtime or exceed their maximum voltage?
Yes, the XM-L has much lower voltage drop than earlier LEDs - this means that with the same battery voltage, there's more voltage and therefore power being dissipated in the 7135.
