T
tomcat017
Wow, great thread! Thanks for putting this together. Some lumens factory data would be great if anyone has it
is it safe to assume that any bulb (including SF) that would run on 2x18650 will also work on AW "C" batteries in a 2xC configuration?
Thanks.
Curtis
I'm almost sure it would be. The voltage is the same, the protection circuit cuts off at about 5.2 to 5.5A draw from both batteries (assumes newer PTC of 18650). Only main difference is more energy stored in C Li-Ion (3300mAh vs. 2200 mAh in 18650)
Assuming the current draw values are right, does this mean I can run a ROP LE with two cells that handle 4 amps of current draw?
Hi rikvee,
Most of our lamp specs could be found on our site under "Specifications", you can find the current draw of them there.
Cheers,
Mark
