Hello Terry,
No.
NiMh is a different chemistry and is charged using a different algorithm. It uses a constant current method and lets the voltage go to wherever it ends up. NiMh chemistry does note rapidly vent with flames when the voltage gets a little high.
With NiMh charging, the higher current charge rates will charge the cells faster, but also cause the cells to heat up. Heat destroys the cells, so, once again, there are trade offs.
You can charge NiMh and NiCd cells in as little as 15 minutes. With Li-Ion cells, the best you can do is get them to around 80% in 15 minutes.
Tom
