Phaserburn
Powerstream 1/2 D\'s vs. Magcharger Stock batts
I recently purchased the Powerstream 1/2D's for my Magcharger with intent to run a Welch Allyn 01160 bulb (5V, 3.45A, billyuns of lumens... well, alot anyway). My question was, is there a difference between these cells and the stock ones? There is a stated capacity difference of 2200 vs 2500mah. But how about the performance? I ran two tests for voltage and current. The first was on freshly charged cells. The second was after 10 minutes of runtime on each using the M/C and 01160 bulb. The results:
Fresh off charger -
Mag Stock - 6.84V, 3.65A
Powerstream - 7.17V, 3.75A
After 10 Mins runtime -
Mag Stock - 6.26V, 3.53A
Powerstream - 6.41V, 3.64A
Seems the Powerstreams are a good investment if you are intending to run the same combo I am (which I have additionally outfitted with UCL (D size works) and Clip 'n' Grip (which significantly assists in carry-ability). I got 10 for $36, shipped. /ubbthreads/images/graemlins/cool.gif There is no reason to get them shrink wrapped; they fit fine as is.
The results of this combo with PS batts/01160 exceeds the Tiger in hotspot, throw AND spill, in any comparison you care to conduct. The Tiger has a better shaped hotspot, but otherwise places second to what I call the "Magcharger +".
Fresh off charger -
