ARC mania
Re: Pre-payment for the HAIII black SF-III.
Happy New Year to all!!!!!!
Yes, the switch in the re-designed tailcap is a McClicky. I chose this switch because it has a louder clicking noise (compared to the current switch.) has a longer stroke and can handle a lot of current. The so called "King's Crown" version tailcap uses the old Kroll switch. This switch tends to melt under-load, does not work well with multi function converters and I've hand lots of problems with it in high powered lights. Once the switch is pressed, it seems to have a tactical mode but when pushed until it clicks, the light will go out and when released, the light will be in the next mode. What we want here is a switch that works plus handle the current of high discharge 18650's. The old "King's Crown" tailcap can not be made to use the McClicky or my original custom switch. Also the redesigned tailcap can not be made to the newer SF-III due to the width of the threaded portion of the tailcap.
Another thing I have to mention is that if the black SF-III is made with the old 3pc design, using the McClicky switch, in order to use 18650's, you would have to unscrew the head to insert the battery. If you use CR123's or RCR123's, you can just remove the tailcap to insert the batteries. I hope everyone understands. There are lots of details involved in building this light with some on the inside being pretty critical or this light just doesn't work out.
The reason I chose to go with HA III black for this limited run is not to worry about mis-match. In the past I've gone through hell and back with natural as there were always only a 60 to 70% chance of matching. Plus, I am doing this because in the history of the SF-III, HA III black was never made.
If all agrees to the 3pc design, you will be able to play lego with the older first generation SF-III 🙂
I plan to set the cut-off date on the 11th of January and will put this on the first post.
Here are some pictures of a pimped out older SF-III for your enjoyment. The two reflectors: one on the left is for flood beam and the one on the right is for a spot beam. I can offer both reflectors. You can change them to your liking.
ARC mania
ARC mania
