ArmyTek
All Armytek Predator discussions in one place.
You are welcome.
You are welcome.
Predator v.2.5 & Predator Pro v.2.5
Predator Pro v.3 & Predator Pro v.3
Extreme Beam Distance
Due to Long-Range Optics Technology even with a compact-size reflector your target is detectable at 450 meters distance.
Distinct hotspot and minimal spill guarantee directed aim illumination. New XB-H LED provides impressive brightness 700 lumens.
Constant Ultra bright Light
Pro: Due to FLAT Runtime Technology the brightness remains constant even in -25⁰C frost and with almost discharged batteries.
Even in Maximal mode the brightness is the same for the whole operation time.
Designed for Weapon Mounting
Standard 1" body diameter matches up with most weapon mounts. Reliable body, red/green/blue filters and original remote switches
for comfortable Hunting and secure Military application. No failures while shooting.
Light-weight, durable & waterproof
Made of aircraft-grade aluminium using the Slim Profile Technology in combination with functional ergonomic design.
Guaranteed durability — stands up the recoil of any gun gauge and falling from 30 meters height. The flashlight works for more than 5 hours at 50 meters depth.
Up to 4 months of Constant Light
Pro:Record runtime with 1x18650 Li-Ion battery due to the Firefly Technology. Compatible both with rechargeable 18650 Li-Ion and non-rechargeable CR123A batteries.
Armytek Tactical Lights
