PhotonWrangler
Just had an LED failure in one of these Stick N Click lamps.
These use three AA cells and a 10 ohm resistor in series with a single LED and an on/off switch. There was no smoke or flickering - the LED just went open circuit.
I inspected the LED closely and there's no discoloration on the die cup and the bond wire is still in place. This is the first time I've seen an LED that just quietly went -poof- with no physical signs of distress. Makes me wonder if the others are likely to fail in the same manner.
