problem in design of torch
dckjain
i want to design a torch in which i am supposed to use any number of 5mm LED but i should be able to throw a light for about 250-300 feet (75-90yards)
what should be the optimal number of LEDs and the lumen's required
and the rechargeable battery required for the peak use of around 2- 3 hours
please suggest any reflector and lens if u have any idea.
actually i am from india and dont have enough idea about long range torches
please help me
5mm LEDs are not designed for throw. The have a beam pattern of 15-20 degrees typical which is determined by the manufacturer. A light that has lots of throw has a beam pattern of 6 degrees or less...
The only way (that I know of) to have lots of throw from a 5mm LED light is to have lots of LED. This way, the large volume of light (high lumens) produced will give you 'throw'.
If you dont know anything about torches, it would probably be a lot easier to buy one instead..as said, you will not get a lot of throw from 5mm LEDs :candle:
You could use 10mm LEDs instead. They still aren't the optimal solution (which would be a Cree and the appropriate reflector), but their beams are rather more concentrated than those of 5mm LEDs.
