casebomber
It seems a fair amount of people don't like 3 aaa lights. Why is this?
ppl don't like many things, i wouldn't think much about it.It seems a fair amount of people don't like 3 aaa lights. Why is this?
often the 3x AAA light items are direct drive or resistered drive, which is good somewhat, but makes it more difficult to use many chemestries. many of the 3xaaa will overdrive strongly with lithium cells. often work good with Alkalines :sick2:
......They have poor personalities. That's all.
Not if you consider that NiMH Eneloops can be used. NiMH rechargeable is why 3AAA makes sense to me. I don't want to be forced to use lithium primary or have the troubles of Li-Ion rechargeable (compatibility, dangers, chargers, etc.).When you look at the cost of 6 AAA batteries, the cost of 2 CR123s is pretty comparable. There's no reason to cheap-out when CR123s exist and are much higher quality.
Exactly. AAAs and AAs are usually priced the same, but 3xAAA batteries contain the same amount of energy as one AA. So you are paying three times as much for your electricity.
not really, voltage alone doesn'tmean much,This has been said repeatedly in this thread, but 1AA is 1.2v-1.5v and 3AAA is 3.6v-4.5v, no? Isn't the light output much brighter with 3AAA as compared to 1AA?
you do know there is such concept as capasity for cells, that mesures in mAh, or Ah.
1 aaa 1,5v and 800mah, 1 aa 1,5v 2500mah. (average cell numbers, capacity also depends on draw\load, at high draw rater capacity drops)
so 3aaa 4,5v =3,6watts hour
1aa 1,5v =3,75 watts hour
so 1 aa has as much energy (don't mix with voltage) as 3aaa.
thou numbers vary, some cells are 1,2v and some almost 1.7v ,even more for nizn cells
Not easily, because the voltage is different. That said, a Li-Ion would work well, and I have dropped 17500's in a couple old multi-LED lights.what I am wondering is: does/can any make a C cell adapter that would work in these lights?
