SouthernSorrows
- Joined
- Jan 15, 2007
- Messages
- 90
So I nabbed an Armytek Viking v3 for $34 on their black Friday sale which is great, I like Armytek BUT I just got it in the mail a few hours ago and It's giving me problems with mode switching "I think the tail switch is bad....hopefully :shakehead"
THE ONLY way to switch modes is to have the light turned OFF then half-press the rear switch to change output mode and while holding in the half press on a mode you want, fully press the switch in the rest of the way until it clicks, now you're in whichever brightness setting you half-clicked to.
Now if you let go of the half press before fully pressing it in until it clicks, you lose your setting and have to cycle through them all from firefly on up all over again....and half of the time even that method does not work . It also will not remember the last mode used, if I turned the light off and my last mode used was High when I turn back on I'm now in Firefly :hairpull:. I can also cycle modes by turning the light on/off rapidly on-off = firefly , on-off now = low etc.etc..
I tried cleaning contacts,pulled the tail cap apart checked that out, tried different batteries both 18650 protected and duracell cr123a's, cleaning threads etc.etc.
The turbo mode function works and also the disable/enable strobe mode function works so I don't think the problem is in the head "could be wrong?"
Reeeally wish I wouldn't have sold the predator I had, I could have stolen the *** end off that and tried it on the viking
pardon all the emogi's, I'm half italian and I can't talk with my hands through a keyboard >_<
