KevinPJ
First of all, I'm new here so hello :wave: and I hope that I posted this in the right forum.
A few weeks ago I bought a Fenix LD20 R4 (the 205 lumen version) and it was all awesome. I tested all the modes and they all worked.
Then, about 10 days later, the turbo mode stopped working. When the flashlight is on and I tighten the bezel to go into turbo/strobe modes the flashlight now gives a flash of I guess 205lumen then goes down to what appears to be it's high setting.
Then, after using the flashlight for maybe 10 minutes the high mode doesn't work. When I try to go into high mode it will just flash and go to medium mode. At this point I tried going into the turbo mode thinking it might flash and go to high mode but it instead went all the way down to medium.:shakehead
I thought maybe the batteries (Alkaline duracell procells) where bad so I checked the voltage but they seemed OK at 1.2 volts (each).
I have not used this flashlight in temperatures under 20ºC and never had it turned on more than 15 minutes.
I then put some fresh batteries in and everything worked until the batteries discharged to 1.4volts (each). Then the turbo mode was unavailable.
I've cleaned the contacts with alcohol on a swab like Fenix says you should on their tutorials.
Is there anyway I can fix this? I live in a pretty remote place and sending it to fenix or amazon is going to cost me quite a bit.
Thanks.
Thanks.
